DC fuel tank question
Old Jan 30, 2013 | 05:10 PM
MeanMugen's Avatar
Icon2 DC fuel tank question
Im building my first car from the ground up basically its pretty much a shell with few interior pieces but everything else was stripped brake lines fuel lines etc.
I need help with running my fuel lines i just wanna know which hose is which. I don't really have anybody to ask at home so i decided to post on here. I have a stock fuel tank no fuel pump & no existing lines. My question is are there 2 lines running from the fuel pump? & also is there another line running from the bottom of the fuel tank? i just need some guidance im sure it's pretty simple but i havent had time to look at any other integras. please help!
here's a pic of my car:
Old Jan 31, 2013 | 11:46 AM
kchungb17a's Avatar
Default Re: DC fuel tank question
You should always start with year and model of your car.
There is nothing on the bottom of the fuel tank. You have one line running from the fuel pump/sending unit and another line which is a return from the engine.
The diagrams on these links are for an '01 GSR. Double click on the diagram to enlarge:
http://www.acuraautomotiveparts.org/...s=&view=normal
Old Jan 31, 2013 | 12:01 PM
kyden's Avatar
there's 3. one from the pump to the engine. one from the engine back to the tank. third is the evap line.
Old Jan 31, 2013 | 01:49 PM
fcm's Avatar
fcm
Old Fart
Ditto the above, MM&Y and trim level of car always helps.
This is a 95 LS... http://www.acuraoemparts.com/delray/...All&vinsrch=no 94
Old Jan 31, 2013 | 08:14 PM
kchungb17a's Avatar
Ah yes, evap line. The damned evap line...
Old Jan 31, 2013 | 11:15 PM
MeanMugen's Avatar
sorry my bad its a 95 ls & yes where does the evap line lead to?
Old Feb 1, 2013 | 03:26 PM
kchungb17a's Avatar
fcm, did you know this was a 95 LS or did you just happen to post the link to one?
OP: the evap line goes to a rubber hose which attaches to the "2 way valve" (#3) in the linked diargram) which clamps to the front left corner of the fuel tank and connects to another rubber hose that goes to the fuel tank.
Old Feb 1, 2013 | 03:34 PM
fcm's Avatar
fcm
Old Fart
I can read minds.94
Old Feb 1, 2013 | 03:43 PM
kchungb17a's Avatar
That's what I thought.
MeanMugen
Feb 3, 2013 08:17 PM
maketoast
Aug 2, 2011 07:06 PM
JesseR
Oct 13, 2003 09:27 AM
djdxm
Jun 20, 2003 08:52 PM
Ham'ed Hatch
May 17, 2002 08:43 PM
