DC fuel tank question
Old Jan 30, 2013 | 05:02 PM
MeanMugen's Avatar
Icon2 DC fuel tank question
Im building my first car from the ground up basically its pretty much a shell with few interior pieces but everything else was stripped brake lines fuel lines etc.
I need help with running my fuel lines i just wanna know which hose is which. I don't really have anybody to ask at home so i decided to post on here. I have a stock fuel tank no fuel pump & no existing lines. My question is are there 2 lines running from the fuel pump? & also is there another line running from the bottom of the fuel tank? i just need some guidance im sure it's pretty simple but i havent had time to look at any other integras. please help!
here's a pic of my car:
Old Jan 31, 2013 | 11:13 PM
MeanMugen's Avatar
Default Re: DC fuel tank question
ttt wow really nothing anybody?
Old Feb 3, 2013 | 07:25 AM
ayoitzmayo's Avatar
try googling it
Old Feb 3, 2013 | 07:56 PM
Shafto's Avatar
One will be a quick disconnect which I believe is your main supply/pressure line, the other runs a standard hose clamp which is your return. The EVAP system may be doing something funny in there so I dont really know. Hopefully someone else will have a better know how.
Do you have the manual?
Old Feb 3, 2013 | 08:16 PM
CrxB16a2's Avatar
Your 5/16 line is the feed that runs in the center. The two 1/4in lines are fuel return and evap. Ran more towards the driver side. Then the two 3/16in brake likes are ran towards the passenger side. All the lines run underneath on the driver side im just stating the order they go in. The main line hooks to fuel filter in engine bay. Return to fpr. And evap line to canister.
Old Feb 3, 2013 | 08:17 PM
CrxB16a2's Avatar
Also i'd highly recommend pre bent lines from oemacuraparts.com
MeanMugen
Feb 1, 2013 03:43 PM
RoadRaceMike
15
Apr 24, 2011 05:23 PM
1slwcoupe
Mar 31, 2007 07:59 PM
JesseR
Oct 13, 2003 09:27 AM
djdxm
Jun 20, 2003 08:52 PM
