Really bad oil leak
Old Jan 30, 2013 | 03:36 PM
Mr2Rotor's Avatar
Default Really bad oil leak
Hey guys I have an EJ8 with a GSR swapped into it. I noticed I've been losing a lot of oil and wondered where it was coming from. Well now I found the culprit but Idk what it is.
It's shooting out of that gold thing in the middle
Old Jan 30, 2013 | 03:52 PM
jdm_phunk's Avatar
Default Re: Really bad oil leak
That looks like an oil pressure split valve for your oil pressure sensor and turbo oil supply line that has been blocked off. http://i19.photobucket.com/albums/b1...e/P1070746.jpg
You can take it off assuming your not running a turbo and put your oil pressure sensor back into the block(use Teflon tape or/Honda bond for the threads). Maybe the engine was turbo prior to you buying the car/or engine??
Old Jan 30, 2013 | 04:06 PM
Mr2Rotor's Avatar
Yea the car was turbo before I bought it. So which part do I take off? just that gold nozzle part? or that whole thing?
Old Jan 30, 2013 | 04:11 PM
jdm_phunk's Avatar
You can take off the whole split valve and just keep the oil pressure sensor(of course)and put it back in the block like at was from factory like this ---> http://www.ff-squad.com/tech/sensors/oilpressure.jpg
xkrazyxjbrkerx75
Aug 9, 2011 02:47 PM
x92preludesix
Mar 21, 2007 12:35 PM
crvtkllr
Oct 22, 2006 01:22 PM
b00stedbyFastrax
Nov 29, 2005 02:54 PM
