d16z6 in ef. running rough no codes
Old Jan 30, 2013 | 10:35 AM
Shadowcat's Avatar
Default d16z6 in ef. running rough no codes
ok so we just got done putting a full d16z6 swap into a 1991 civic ef hatch dx. so heres a video of it running.
http://www.flickr.com/photos/69121561@N02/8430802658/
obiously it runs like crap. so i was wondering if anyone could help us out a little. we did the dpfi to mpfi and the obd0 to 0bd1 conversions. running on a oem p28 ecu. also used a rywire obdo to obd1 harness but we double and tripple checked our wiring and its all correct. no check engine light when running(like this anyways) turning the distributor back and fourth only helps it start doesnt fix the way it runs. also calibrated tps to .45v and 4.5 WOT.
ok so i checked the timing 5 times and made sure it was right. so were were thinking the valves might be out of adjustment. anyone have suggestions or know exactly whats wrong with it.
Old Jan 30, 2013 | 10:51 AM
Former User's Avatar
Default Re: d16z6 in ef. running rough no codes
Does the CEL work?
Spark plug wires in correct order on cap?
Mechanical timing dead on? Post pictures.
All plugs have spark?
All injectors spray fuel?
Old Jan 30, 2013 | 11:13 AM
Shadowcat's Avatar
cel code works. when we first fired it upm it threw a code for o2 sensor. fixed it didnt change anyhting and cell went away.
check firing order 3 times.
yes. spark at all 4 cylinders.
yes. all injectors are spraying.
http://www.flickr.com/photos/69121561@N02/8430981166/http://www.flickr.com/photos/69121561@N02/8430981166/ by http://www.flickr.com/people/69121561@N02/, on Flickr
http://www.flickr.com/photos/69121561@N02/8429894673/http://www.flickr.com/photos/69121561@N02/8429894673/ by http://www.flickr.com/people/69121561@N02/, on Flickr
Old Jan 30, 2013 | 11:26 AM
Looks like the crank pulley may not be set to TDC1. The pointer should align with the single TDC1 white mark rather than marks in the group of three.
Old Jan 30, 2013 | 12:18 PM
Shadowcat's Avatar
Ok so its set at a group of 3 marks. Theres the three timing marks. And the to the right of it (looking at the bolt) there is 2 marks.
Old Jan 30, 2013 | 12:20 PM
One of the two marks to the right of the group of three marks is the TDC1 mark. Not sure which one.
Old Jan 30, 2013 | 02:31 PM
Shadowcat's Avatar
Ive set it to both. No change
Old Jan 30, 2013 | 02:36 PM
Is there even a tooth's difference between the two marks? At this setting, compression test your cylinders.
And why the aftermarket cam piulley? The stock TDC1 alignment for the D16z6 looks like this:
Your cam may be off by a tooth or two.
Old Jan 30, 2013 | 04:28 PM
Shadowcat's Avatar
the pully is just for loooks. pulling off the purple and yellow look. ill try putting the stock cam gear on and timing it again.
Old Jan 30, 2013 | 04:31 PM
FoorBangar's Avatar
Putting a d16z6 in an ef is like putting a k20 in a type r.
Old Jan 30, 2013 | 06:05 PM
Shadowcat's Avatar
Ok so we put the stock gear on and switched which of the two lines on the crank. It startedafter holdig the throttle all the way open. But its weird. It wont let my rev it up it seems as if it was cuttig fuel so it wouldn't rev up past idle. So i thought tps. But i sparyed starter fluid into the tb until we finally got it to run. It idled fine and it revved up with the tps unplugged. When we went to turn it off it wouldnt start back up.? Any ideas. Clogged fuel injectors? Bad tps?
Old Jan 30, 2013 | 06:47 PM
Maybe still one tooth off. It should run with the TPS plugged in.
Old Jan 30, 2013 | 08:36 PM
Shadowcat's Avatar
ok so we got the timing right finaly. however the stock cam gear wobbles a little and tries to push off the belt. but after spraying more starter fluid in it to get it to run and rev up. i unplugged the tps and i blead the coolant. it doesnt have a vss in it right now but we drove it around my neighborhood a couple times really slowly. when we got back into the garage (had to slowly release the clutch to turn it off, hopefully its just some wiring but its something with the ignition not turning the car off.) i turned if off and started it and reved it up and repeated it like 5 times. it seams as if driving it helped clean some crap out? this was all done with the tps unplugged.
Old Jan 31, 2013 | 09:58 AM
Shadowcat's Avatar
so when the motor is cold. i have to sray a little bit of starter fluid to get it started. but when it warms up and i shut it off it starts right back up? anyone?
Old Feb 1, 2013 | 04:41 AM
Shadowcat's Avatar
anyone!?!?! i really need help on this
Old Nov 26, 2014 | 05:29 PM
SPL KID's Avatar
Ever resolve this? Seems like the P28 doesn't run the D16z6 well in a EF chassis. As mine does almost the same thing. I put in a P06 and it runs great!
Old Nov 28, 2014 | 02:20 PM
4drEF's Avatar
Keyboard Humorist
A p28 is the computer for the z6.
It could flawlessly run the z6 outside of the car on the ground if it were all wired correctly.
Chassis has nothing to do with it.
messy.
Feb 12, 2018 12:44 PM
Wrwatson3
Engine Management and Tuning
Mar 5, 2014 01:14 PM
efhonda_21740
13
Jul 15, 2011 10:48 AM
N'viouzEF9
20
Jan 22, 2011 07:54 PM
Red_Si
Oct 25, 2006 02:21 PM
