Getting through firewall on 1994 Honda Accord EX
Old Jan 30, 2013 | 08:28 AM
geigerm's Avatar
Default Getting through firewall on 1994 Honda Accord EX
Hey guys I hope I am posting this in the right section, if not I do apologize.
So I drive a 1994 Honda Accord EX Coupe (Manual).
I am in the process of installing an amp for my car audio. Trying to run the power cable from the battery to the amp but I am having trouble with getting through the firewall. I can see the firewall on the passenger side right behind the glove box. I took the glove box out but there is just no way for me to reach into there, I can barely get my flashlight to shine line onto it. So I tried to go from the hood inside the car and even then my hands won't reach the firewall so that I can cut into it for my wire to run through. Is there any other place to run the wires that won't require drilling? I spend about an hour last night trying to make this work but I just can't seem to reach anywhere that I try, quite frustrating.
Anyone have any advise for me?
Old Jan 30, 2013 | 08:41 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Getting through firewall on 1994 Honda Accord EX
There is a grommet on the firewall behind the throttle body area that pops out and puts you on the right side of the center console/left side of glove box by the ECU. It's used for the OEM foglight kit.
If you look at the matting/deadening under the carpet you should see a circular punchout area
Old Jan 30, 2013 | 10:01 PM
geigerm's Avatar
Hey thank you so much for your help. Got that part figured out.
But now I have run into another problem, hopefully someone can help me.
I am trying to power my amp but for some reason it is not turning on. I have a feeling it is the remote wire but I am not sure. If I jump the amp it will turn on but it won't turn on via the remote wire. I have an aftermarking HU and the amp is connected to it via blue and white cable labeled P. Connect.
Any advise would be appreciated.
Jakejjohns
Apr 19, 2016 03:01 AM
Danntek
Dec 30, 2013 05:12 AM
SteveSOL
Audio / Security / Video
May 2, 2012 06:13 AM
All4fun
10
Oct 10, 2009 08:43 AM
gatrhumpy
Apr 5, 2009 01:34 PM
