JDM ZC swap into EG - Will d16z6 motor mounts work?
Old Jan 30, 2013 | 06:02 AM
metalslug's Avatar
Default JDM ZC swap into EG - Will d16z6 motor mounts work?
Have this posted on the "all motor" section but not much going on so I'm trying here. So so far I have found that everything will work but no real answer as to if the z6 mounts will work. I have googled and searched, zc forums and still no real answer. I hope some one can help. Thanks in advance.
"So my z6 blew up, now I'm considering a swap with a ZC. I should mention the z6 I have its an auto so my questions are:
1. Will my z6 auto trans bolt up to the ZC?
2. Anything that I need to know about the exhaust header bolting up to my stock exhaust system?
3. Will my axels work?
4. Will my d16z6 motor mounts work?
5. Will my z6 harness work?
Anything else I should consider? Below is the list of what comes with the ZC I am thinking of buying, any help/input would be appreciated.
Product Description Specifications:
DOHC 4cyl. 16valve
Make: Honda
Model: Civic
Engine Type: Performance
Year: 92-95
HP: 137hp@6800
Torque: 08lb-ft@5700
Redline: 6700 rpm
Diplacement: 1595cc
Compression Ratio: 9.1:1
Transmission Type: Automatic
Mileage: between 20 to 35 thousand miles
List Of Parts Included:
• Complete Motor
- Block
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- Headers
-Engine only
• OBD1 ECU (Computer)
• Automatic
• Intermediate shaft"
Old Jan 30, 2013 | 06:07 AM
Former User's Avatar
Default Re: JDM ZC swap into EG - Will d16z6 motor mounts work?
Thread titled edited to include the main question of the thread.
unknown0001
May 27, 2007 06:19 PM
BlueRex1020
10
Oct 10, 2006 01:51 PM
bearboy80
Apr 10, 2004 11:02 AM
CRX A4
15
Sep 17, 2002 09:51 PM
