CA FS (SoCal): 1991 Mazda Miata NA white - clean title
Recent maintenance completed (in the last 1000 miles):
- fresh oil change
- fresh transmission fluid change
- fresh differential fluid change
- new drain bolts
- new Federal 595RS tires
- replaced w/ new factory speedometer cable
- alignment, all 4 corners
- new spark plugs
- new header gaskets
- new PCV valve
- new air filter
- previous owner replaced in mid-2010: heater hoses, timing belt, clutch, waterpump
- rubber shift boot insulator
Garage kept hobby car. Not getting enough use out of it, and could use the garage space back. Car has full folder of maintenance records from last 4 owners.
Great selling points:
-clean title
- frame is absolutely straight
- passes smog
- soft top is in excellent shape, no tears
- no cracks in dash
- interior in good shape
- no rust
-AC runs cold
- non smoker car
Aftermarket/upgraded parts:
- Personal suede 350mm steering wheel
- Racing Beat front lower tie bar
- Hard dog roll bar
- Goodwin front and rear tow hooks
- Advan RGII front rims, white
- Gramlight 57 Optimise rear rims, gunmetal
-green Muteki extended lugnuts
- RacingBeat springs and KYB AGX shocks
- rear fiberglass canards
- front rubber canards
-Wiseco battery
- Voodoo shift ****
MILEAGE: 190,000
PRICE: $3500 OBO
Cheesefries333
Jan 17, 2007 08:08 PM
94jrscgsr
Mar 30, 2004 05:58 AM
