ZC into EG swap inquiries....
So my z6 blew up, now I'm considering a swap with a ZC. I should mention the z6 I have its an auto so my questions are:
1. Will my z6 auto trans bolt up to the ZC?
2. Anything that I need to know about the exhaust header bolting up to my stock exhaust system?
3. Will my axels work?
4. Will my d16z6 motor mounts work?
5. Will my z6 harness work?
Anything else I should consider? Below is the list of what comes with the ZC I am thinking of buying, any help/input would be appreciated.
Product Description Specifications:
DOHC 4cyl. 16valve
Make: Honda
Model: Civic
Engine Type: Performance
Year: 92-95
HP: 137hp@6800
Torque: 08lb-ft@5700
Redline: 6700 rpm
Diplacement: 1595cc
Compression Ratio: 9.1:1
Transmission Type: Automatic
Mileage: between 20 to 35 thousand miles
List Of Parts Included:
• Complete Motor
- Block
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- Headers
-Engine only
• OBD1 ECU (Computer)
• Automatic
• Intermediate shaft
DOHC 4cyl. 16valve
Make: Honda
Model: Civic
Year: 92-95
HP: 137hp@6800
Redline: 6700 rpm
Diplacement: 1595cc
• Complete Motor
- Block
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- Headers
-Engine only
• Automatic
metalslug
Jan 30, 2013 06:07 AM
