Cross-fitting Cat to match new exhaust
I'm bolting on a new exhaust system: megan headers (4-2-1), and a yonaka cat back (ycmb002). And I'm looking for a direct fit high flow catalytic converter (not up to california standards, I'm in Florida) to match up with everything. I've dug on the internet for a cat for my 4dr 97 Gs (dd'd), but everything I'm finding has a 1.8 inch outlet.
The header collecter is 2 inches, and the Yonaka has a 60mm(2.36in) piping. I want to keep everything as a bolt in setup to avoid welding more than I have to. So my question is, does anyone know of a cat that will work for this setup? 2inch inlet, with an o2 spot, and an outlet pipe that is at least 2 inches or preferrably up to the 2.36 so everything can bolt in directly.
I know that the yonaka kit I'm getting will need 4 inches added on to the b pipe to reach from under the bumper. Hopefully I'm not missing something right in my face. And the other stipulation that needs to be met, is that it can't dangle ridiculously far below the car because I do plan to lower it in the future
Thanks to anyone who can offer input or point me in the right direction to finding something.
Tl;dr I need a direct fit highflow cat with a 2inch inlet, o2 hole, and 2-2.36inch outlet, that doesn't hang further below the stock cat for lowering purposes.
iBrandon
Aug 11, 2004 11:53 PM
sanjiyan69
Jul 21, 2004 03:49 PM
