Cooling fan issue?
Old Jan 29, 2013 | 04:38 PM
zsiya's Avatar
Default Cooling fan issue?
Started working on my 91 LX. Changed t-stat, car hasn't run hot. The cooling fan (passenger side) seems to come on only after I shut the car off. Then it runs a LONG time. It will also come on with a cold engine and just turning the key on for a second. Any ideas?
Also, the engine side of the t-stat housing gets really hot while the lower hose barely gets warm. No bubbles in radiator and I'm stuck like chuck on the next move.
Old Jan 29, 2013 | 08:18 PM
Accord1320's Avatar
Default Re: Cooling fan issue?
I am also experiencing the weird fan thing with my 91 EX. I turn off my engine and my fan still runs, until I open my door, thats when it stops. And in the morning, its hella cold and it turns on when I turn the key to the ON position but without starting the engine.
I checked my relays and it is definitely not it. Otherwise, the fan would not be working at all. A friend of mine guessed that someone (previous owner or mechanic) bypassed some wiring to keep the fan on so that the car doesnt overheat. Thats why when a few days ago, I posted on my overheating thread, I mentioned that there was nothing left of my thermostat, which was why my engine got hella hot quick.
I would check the wiring. Was your ride previously owned?
Old Jan 29, 2013 | 08:44 PM
NZXTInerTia's Avatar
Mine used to do that every time I turned the key to On, and then off (obviously when I stopped my car after using it as well). When I replaced my leaky radiator hoses and topped off the coolant it went away...
Old Jan 30, 2013 | 02:39 AM
Michael H's Avatar
the same problem with mine 91LX too just looking for some convenient method to sort out this weird problem
Old Jan 30, 2013 | 03:19 AM
Chris Jimenez's Avatar
ya i have the same issue and i have recently replaced the upper radiator hose and toped of the coolent in both the radiator and over flow
Old Jan 30, 2013 | 03:20 AM
o ya i have a 94 accord ex
Old Jan 31, 2013 | 08:45 AM
Bad_dude's Avatar
Icon3 Re: Cooling fan issue?
Check the timer. It suppose to run the fan when the engine is hot after shut of from a drive and only for 10 minutes and no more. If the timer is bad the fan keeps running.
technine
Mar 19, 2009 04:12 PM
eric_ches
Dec 29, 2007 01:49 PM
a12rnulfo
Jun 18, 2006 08:19 AM
Kashi
Apr 13, 2005 07:09 PM
Caveman74
Mar 16, 2003 05:56 PM
