Question after Seafoming
Old Jan 29, 2013 | 11:41 AM
zsiya's Avatar
Default Question after Seafoming
I Seafoamed my 91 LX and when I started it back to clear it out, "smoke" came from around the headers. The heat shield is still on so I'm not sure exactly where it's coming from; but the front of the engine. Problem? If so, how big?
Old Jan 29, 2013 | 11:57 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Question after Seafoming
Well, likely an exhaust leak, since that's where the exhaust comes out...
Old Jan 29, 2013 | 12:37 PM
zsiya's Avatar
That's what I figured, but since I can't see the header, I wasn't sure if there was something else I should look for.
Old Jan 29, 2013 | 12:53 PM
Accord1320's Avatar
Check your seals or gaskets. One of them may be done for or incorrectly placed, causing a leak.
Old Jan 29, 2013 | 05:33 PM
holmesnmanny's Avatar
Exhaust leaks cause you to burn more fuel than usual and it can foul your oxygen sensor and catalytic converter. Take the heat shield off so you can get a better look. You should fix the leak asap.
Old Jan 29, 2013 | 06:22 PM
NZXTInerTia's Avatar
If its smoking from that area you could have a crack in your exhaust manifold. I did, that's the main reason I upgraded to headers.
Old Jan 29, 2013 | 07:28 PM
Mishako129's Avatar
I had smoke coming from the exact same area after SF (seafoam) and when I eventually took the manifold off it was cracked in not one but 2 spots! Then when I took the cyl. head off I found it had 2 burnt exhaust valves. I think that the cracks in the manifold are what caused "hot spots" and burnt the valves, what do you think?
Old Jan 29, 2013 | 08:13 PM
Here's a picture of mine, I can't remember what runner cracked either 1 or 4. I just replaced them with headers and it was a done deal. But OP, if you go this direction don't get cheap eBay ones. That's a quick easy way out, but they're horrible quality. If this is even your issue.
ohemgiii
Oct 2, 2015 08:38 PM
Krylon360
17
Mar 12, 2013 06:00 AM
Shinghi
Mar 6, 2012 10:46 PM
sloweh3
10
Jul 28, 2008 09:48 AM
acidburn2k2
Jan 7, 2006 01:03 PM
