ITR throttle body....................
What size in millimeters is the stock ITR throttle body? I tried doing a search but no luck. Thanks
62 MM, the same as a S2000 T/B.
Same part number gasket found on the ITR's and S2000's i.e.16176-P73-004.
And yes, a S2000 T/B will work on a ITR manifold. (Have one right now on my own setup)
Part # for the S2000 T/B # 16400-PCX-A01. Retail for $593.04 (will vary within Honda dealership)
-The only two different that I found is the throttle-linkage has a slight 20 degree outward slant. Has no effect on the trottle, just a minor adjustments with the cable.
-The other is that the S2000's doesn't have a idle adjustment screw. S2000's have a self-mode idle within the computer (ECU) so it doesn't require one. Adjustment can be made by loosen the allen-screw below the actual throttle-linkage. (like on most majority aftermarket T/B's.
I don't have pics to prove this claim but I have a few on this board that seen it.
However, I may do a small review comparision with the two T/B's if I have some time. A buddy of mine is reworking his ITR setup and I might borrow his T/B to take some pics. I'll see what I can do.
=bert
[Modified by SANBST, 6:21 PM 10/21/2002]
chris_m
Sep 8, 2005 10:09 PM
