LS-VTEC Code 16 help
Old Jan 29, 2013 | 06:56 AM
lsvSwagg's Avatar
Default LS-VTEC Code 16 help
so i recently swap my 2000 civic to a fresh built lsvtec and my CEL light turned on its throwing code 16 which is fuel injector im running stock ls injectors with obd1 to obd2b conversion harness . the wire are set correctly and car runs fine . i need help i have no idea why im getting code 16 .
Old Jan 29, 2013 | 07:04 AM
JuggerNaut-CTR's Avatar
Default Re: LS-VTEC Code 16 help
The cause to that particular cel is....bad wiring or unplugged / defective fuel injector
I would check the wiring and clips for the injectors...or...maybe one of the injectors is bad..hmmmm
Old Jan 29, 2013 | 07:08 AM
lsvSwagg's Avatar
if one of the injector is bad wouldnt the car not run right ?
Old Jan 29, 2013 | 07:19 AM
Have you tried a different ecu? Which are you using now?
Old Jan 29, 2013 | 07:21 AM
lsvSwagg's Avatar
im runing a chiped p28 and no havent tried a diffrent ecu .
Old Jan 29, 2013 | 07:26 AM
Check the fuel injector #1 ground wire that runs from the injector to the ECU.
Old Jan 29, 2013 | 07:30 AM
lsvSwagg's Avatar
just checked it and its good
Old Jan 29, 2013 | 07:40 AM
Another thing is the incorrect injector resistance is throwing the code. Measure resistance across the terminals of each injector. Test whether all 4 injector clips get battery voltage. If so, test whether the voltage reaches the 4 ECU pins.
Other then what I listed, I am out of options bro
Old Jan 29, 2013 | 07:44 AM
lsvSwagg's Avatar
allright im check that out and thank you for helping me out
Old Jan 29, 2013 | 07:46 AM
Your welcome...post results...someone else will chime in sometime
93LsVx
Aug 28, 2010 09:20 AM
red91hatch
Jun 6, 2008 06:23 AM
pinoyboy204
Oct 9, 2003 04:57 PM
BIG RICH
Jul 7, 2003 11:00 AM
slywfbpsi
Jun 9, 2003 11:07 AM
