1994 honda accord ex driveaxles
Old Jan 29, 2013 | 12:56 AM
jfizzule's Avatar
Default 1994 honda accord ex driveaxles
Thanks to every one for helping me fix my idle problems. There is a air leak I can't find because I cover the intake and car doesn't cut off any suggestions? Well I would like to know what are the proper drive axles for a JDM f22b sohc vtec I got f22b1 drive axles brand new but idk if there in all the way. Is the black piece suppose to touch the transmission there is small gaps is it suppose to be like that with gAPS. I really need any suggestions because my transmission won't hold fluid for nothing at all and I can find no leaks at all.
Any suggestions on transmission leaks were to look
Do I use sealant on intake manifold gasket.
Can I put grease on drive axle tip to make it go into transmission better
Old Jan 31, 2013 | 05:33 PM
nus_dogg's Avatar
Default Re: 1994 honda accord ex driveaxles
As long as the shiny shaft part is not showing then you're good. It should be really close to the transmission, but it shouldn't touch. Also, listen and feel when you push it in. It should click and bottom out.
Benny Honda
Suspension & Brakes
11
Dec 17, 2016 09:42 PM
pasadena_commut
Dec 22, 2014 08:44 PM
Sorcerer
Sep 29, 2010 03:41 PM
bdmlilburn
Mar 25, 2009 04:56 PM
1999 honda Accord Cali
Jun 8, 2008 08:36 PM
