will a itr suspension fit on a crx with no problems
Old Oct 20, 2002 | 08:43 PM
01-0720's Avatar
Default will a itr suspension fit on a crx with no problems
iv seen it done i just wanna no what if anything needs to be done to make it work or does it bolt on like it whould on any other civic
thanks
eric
Old Oct 20, 2002 | 09:22 PM
01-0720's Avatar
Default Re: will a itr suspension fit on a crx with no problems (01-0720)
up
Old Oct 21, 2002 | 06:13 PM
01-0720's Avatar
no one knows
Old Oct 21, 2002 | 06:46 PM
nfn15037's Avatar
Hybrid forum is your friend.
Old Oct 21, 2002 | 06:49 PM
RagingAngel's Avatar
Default Re: will a itr suspension fit on a crx with no problems (nfn15037)
the lower control arms in the back have to be changed unless you have an 88CRX..then it might fit..
the upper control arm in the rear was changed on a buddy of mine's as well.
you will need to use ITR front forks.... and mrmmm..I think the front lower control arms as well....
IM AJ PWR for more details.
Old Oct 21, 2002 | 07:08 PM
xtrafastcivic's Avatar
Default Re: will a itr suspension fit on a crx with no problems (RagingAngel)
are you talking about 5 lug swap or shocks and springs??
if your talking about shocks and springs the guy above me covered it and if you're talking about 5 lug here...
http://www.jarofbees.com/tech/da_5lug/
Old Oct 21, 2002 | 09:13 PM
01-0720's Avatar
Default Re: will a itr suspension fit on a crx with no problems (XtraFastCRX)
yeah im talkin about the whole 5 lug conversion its goin on a 88 hf
Old Oct 21, 2002 | 09:29 PM
MiraiZ's Avatar
88 HF suspensions is totally different even from the 89 HF...it won't be plug & play...as a matter of fact, I would go as far as saying that finding anything for the HF will be difficult
Old Oct 21, 2002 | 09:48 PM
01-0720's Avatar
Default Re: will a itr suspension fit on a crx with no problems (MiraiZ)
so the 5 lug wont go on there
Old Oct 21, 2002 | 11:17 PM
thaiphob's Avatar
Nikon!!!
anything will work if you have the time and $$$.
Old Oct 22, 2002 | 09:50 AM
01-0720's Avatar
Default Re: will a itr suspension fit on a crx with no problems (thaiphob)
will a 5 lug go on a 89 civic si
Old Oct 22, 2002 | 09:59 AM
Katman's Avatar
5 lug front hubs will NOT bolt up to any 88-91 EF civic/crx or 90-93 DA/integra without machining. Check out this article a friend of mine put together for his DA...
same rules apply to the EF...
enjoy your life on the internet.
Old Oct 22, 2002 | 10:13 AM
Hooch'n's Avatar
Default Re: will a itr suspension fit on a crx with no problems (Katman)
Old Oct 22, 2002 | 10:47 AM
01-0720's Avatar
i understadn it willl need machining , but it does go on thats all i wanted to no thanks for all the info
Old Oct 22, 2002 | 10:48 AM
vtecvoodoo's Avatar
Future Texas Boy
4-lug itr fits.
Old Oct 22, 2002 | 12:45 PM
Katman's Avatar
np..
Just understand that for an EF (88-91 civic/crx) chassis, you need SiR front knuckle assemblies, and you'll need to get a pair of ITR hubs machined to fit inside of the SiR knuckle.
akinas-crx
Oct 6, 2010 11:48 AM
db8db8db8
Oct 16, 2009 04:35 PM
DB8
Apr 13, 2004 10:44 PM
rasta420
Oct 24, 2002 10:18 PM
EFing8
Oct 9, 2002 10:00 PM
