EMISSIONS TEST FAILED! ONLY 10 DAYS LEFT FOR FREE RETEST! HELP!!
So I took my 1996 civic lx sohc (auto) to smog. Says air injection FAIL.
Thanks!
15mph
HC MAX 65/ AVE 9 / MEAS 60
CO MAX .57 /AVE .03 / MEAS .30
NO 487/67/1704
25MPH
HC 49/6/64
CO .55/.03/.37
NO 774/62/1644
Thanks!
15mph
NO 487/67/1704
25MPH
HC 49/6/64
CO .55/.03/.37
NO 774/62/1644
P0720 is an automatic transmission trouble code.
Did the emissions tech explain the Air Injection failure to you? Did you ask?
A bad cat is suggested by the fact that both HC and NOx failed.
oh i did ask him a lot of questions he just said i dont know and sent me to someone to get checked. -___-
could this have anything to do with it being a cat from a y8 and not y7
You need to locate a more helpful worker there. Ask for a supervisor. Tell them that you too are interested in clean air and that you just need some basic guidance on the Air Injection failure.
hes the only person working there unfortunatly...you live and learn...ill go back today though and ask him about it...hopefully he has more to say. i dont want to pay a mechanic for something the smog tech should have explained
appreciate all the help btw!!
in regards to your picture uploaded it said the countershaft sensor was a possibility.
i just replaced both speed/countershaft sensors because i thought it would fix my odometer(not moving) this was after doing the smog.
could the new countershaft sensor affect the emmisions?
If you reset the ECU, does P0720 return?
P0720 could be caused by a bad countershaft speed sensor or by a problem in the circuit or ECU. Use a multimeter to do the electrical tests in the diagram.
Are you noticing any transmission performance problems?
Does the speedometer work but the odometer doesn't?
LAO
Jul 28, 2008 07:00 AM
SimbaDogg
Jul 2, 2003 09:17 AM
