#1,and 2 spark plug soaked in oil why!?!?
so tonite i find a nice little surprise i made a run down to my locale vato zone
for some spark plug wires and when i go to change them out i find #1 and 2 wires soaked in oil. this is the second time i've seen this my buddies old 94 dc
(same year as mine) had the same problem change out the vc with others new gasket and oil change just to make sure it didn't have more than enough
oil and it still did it
i know most are thinking it's the vc gasket but i've already replaced it
um, cheap gasket?? did you clean out where the seal sits? use a little silicone? make sure there is no oil on the surfaces the gasket sits when replacing.
rubber seals harden around the plugs between the VC and head. buy a complete valve cover set, clean well and install it. it's usually those rubber o rings that harden and start leaking
fel-pro is the best bang for the buck. you get a new valve cover gasket, the o rings and all the button seals for less than half of oem
Make sure you use a quality gasket. Cheap gaskets do not fit correctly and may not allow the VC to seal properly. Make sure you replace the fouled plugs.
went ahead and replaced it with a oem one and it seems to be fine
it
was a cheap gasket set i only used it cause it came with car when
i got a couple months ago lol thx for all input
it was a cheap gasket set i only used it cause it came with car when
TunesEK
Jan 15, 2009 01:35 PM
pane93civhb
Jul 19, 2005 12:32 PM
