AIR CHANNEL
Old Jan 28, 2013 | 10:26 AM
SPR876-B18C1's Avatar
Default AIR CHANNEL
not sure if im phrasing this correctly .. or if the ide even makes much sense .. but i just wanted some opinions on this thought, im sure it may have been done before
in the 98 integras there is a hole in the engine bay that is right above the passenger side front wheel .. this hole face the short ram intake i have in my car ..
i was wondering if i was to run a tube from the the bumper(cut out where the fog lights would go) with a velocity stack in it, and the tube to the above mentioned hole with say a mesh so as stop any say fly or unwanted bugs ..
this would increase the amount of cool air that is reaching the short ram intake ... also plan on putting a velocity stack filter on the short ram ..
even thought of taking the design a little further and actually building a cold box around the short ram and connect that same tube to the box ..
does this idea even make sense ??
im guess everybody gonna say jus get a cai .. but i live in a area with alot rain fall and alot of potholes .. so kinda worried about the air filter being so close to the ground .. even tho i know cai should come with woter run off holes ..
Old Jan 28, 2013 | 11:35 AM
doood's Avatar
been there done that
Default Re: AIR CHANNEL
Nothing groundbreaking here. Just do it.
Old Jan 28, 2013 | 06:05 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Better off just buying it
http://www.heeltoeauto.com/comptech-...l-330-121.html
Old Jan 29, 2013 | 07:02 AM
hungrygreen_gsr's Avatar
Or making your own for a fraction of the cost
http://www.team-integra.net/forum/19...style-cai.html
Old Jan 29, 2013 | 07:09 AM
yea think im gonna try this .. thanks
Old Jan 29, 2013 | 08:16 AM
No problem. Look thru the pages and one of the guys showed how to attach and seal in an aftermarket sri into the intake box. It's a better option then running the tiny and power sapping stock intake arm. OR you can go an even better route and pick up a stock ITR intake arm, which is 68mm (+/- 2mm) in diameter, is smooth and straight thru on the inside, does not have the stupid sound resonator, and is plastic so it's better with under hood temps.
Old Jan 29, 2013 | 12:57 PM
yea for sure gonna be running my sri into the box
75aces
Jun 9, 2022 04:19 PM
doubleoazn03
Jun 6, 2009 04:09 PM
findingeverland
Apr 28, 2007 09:50 PM
RaYnE
Aug 12, 2003 05:15 PM
csfalcon
Aug 18, 2002 08:54 AM
