Should I use a P28 or P72 ecu
Old Jan 28, 2013 | 03:19 AM
outage's Avatar
Default Should I use a P28 or P72 ecu
Hers the set up. I have a OBDII B18c motor in a 1996 civic with a OBDII wireing harness adapter. Motor is all stock. I need advise as to what ecu to use. My friend says a chipped P28, I read on alll the forums a P72. Whats your opinon?
Thanks
Old Jan 28, 2013 | 04:05 AM
CO671's Avatar
Default Re: Should I use a P28 or P72 ecu
What's the intake manifold. stock GSR?
Assuming the motor is completely stock, i'd just stick with the stock P72 ECU
A chipped P28 wouldn't be too much different from a stock P72 unless you upgrade some parts here and there.
Old Jan 28, 2013 | 04:53 AM
outage's Avatar
everything is stock, I shouldnt chip a p72?
Old Jan 28, 2013 | 05:14 AM
doood's Avatar
been there done that
stock motor = stock ecu
Old Jan 28, 2013 | 10:14 AM
street_racer_271's Avatar
agree
Old Jan 28, 2013 | 01:50 PM
HondaPartsHero's Avatar
Technical Hero
Also if you have emissions testing in your area which use an OBD2 port connection you'll fail with an OBD1 ECU.
JDMB18CEJ1
Mar 5, 2008 12:45 PM
VTECth1s
Aug 22, 2006 04:22 PM
VTECcnIT
Feb 16, 2006 04:42 AM
hYbRid_Eg6
Jul 31, 2005 09:36 PM
