1997 Civic Ex (D16Y8) Idel Problems
Old Jan 27, 2013 | 02:30 PM
pete1959's Avatar
Icon6 1997 Civic Ex (D16Y8) Idel Problems
I replaced all of the sensors and also the TPS but now when I start the car and let it Idel it surges at idel around 4-500 RPMs at a constant speed going up then down then up then down. Any help related to this would be awesome. The engine is a Y8 Vtec.
Old Jan 27, 2013 | 06:50 PM
Former User's Avatar
Default Re: 1997 Civic Ex (D16Y8) Idel Problems
Vacuum or intake air leak?
Bleed cooling system?
Adjust idle speed?
CEL codes?
Old Jan 28, 2013 | 09:34 AM
pete1959's Avatar
there r 2 codes i keep getting it is that both 02 sensors have gone bad cane both go out at the same time or is there something else causing this tks for your hlp its getting on my nerves lol
Old Jan 28, 2013 | 09:52 AM
thatcivic96's Avatar
I have seen in the past that if the first one fails, it will throw a code for the ones behind it. I don't know if this is just some times or all the time.
Old Jan 28, 2013 | 10:29 AM
Post all codes. Then reset the ECU to see whether they repeat.
Old Jan 28, 2013 | 10:30 AM
+1 see where that gets you. To reset codes unhook negative on your battery for 5 minutes or so.
Old Feb 4, 2013 | 09:51 PM
pete1959's Avatar
ok fixed the idle problem tks a lot it was a vac leak waiting on a code reader i ordered to see whats going on now
whyS0serious
22
Jun 28, 2013 05:56 PM
davidclark311
11
Sep 15, 2010 03:37 PM
zero708970
24
Jan 25, 2010 09:08 AM
socallmechris
Feb 24, 2008 07:28 PM
Kronic
Sep 29, 2003 09:08 PM
