2007 honda accord wont start
does anyone know what the voltage at the coil from the ecm/pcm is supposed to be when cranking the motor over. i have zero from ecm/pcm. or why i have zero is this from bad crank position sensor or other
So your saying that the engine turns over but you aren't getting spark? You've already tested the ignition coil? If you're tps was bad you would be getting a cel, are you? Sounds like the igniter to me, hopefully this helps.
need some ideas on how and what to troubleshoot. i have 12 volts at coil with key on from blk and white wire and when cranking i have zero volts from ecm/Pcm really dont know if this means a damn thing oops .... car just wont start.
Oh, I thought you said you had no voltage to the coil? If you do then you can use an HEI or similar spark tester to see the intensity of the spark at each plug.
*EDIT*
Just realized in my original reply I said tps, I meant cps.
*EDIT*
No cel at all? When you turn the key does the engine crank? Does the engine chug like it's not getting enough fuel or maybe flooding because of too much fuel? Or does it just click? Please provide more details and a list of things that you've tried already.
can any one tell me if there check engine lights goes off after a couple seconds with the key in the 2nd position before starting it? mine stays on does this mean anything
somethings i have tried it compression around 110 for all little low but been sitting for awhile. sprark got 12 volts from bat and got trigger signal from ecm. fuel injectors is a hard one i checked one today and 12 volts going to in and pulse from ecm. oh and took fuel pump out and drained tank and put racing fuel in. and i listen for pump to run and it comes on. and i mean you could eat off this motor. only 20 k on it
Jdm=Ep3
Aug 4, 2018 02:34 PM
