still cranks no start
Old Jan 25, 2013 | 12:36 PM
builtb16civic's Avatar
Default still cranks no start
91 civic w/ obd1 b16 i re wired my engine harness (had no fuel in cylinder)every thing is wired up correctly...now fuel is in the cylinders and THERE IS NO CHECK ENGINE CODES COMING UP..injectors wired correctly to a1,a3,a5,a7....cranks but wont start,main relay is working.. fuses good.. had spark the other day...fuel pump primes...hearing online that bad ign switch will still allow car to crank.how do i test ign swtch..maybe ill recheck for spark????? everything seems to be working correctly(obviously something aint) but cranks got fuel.... i have a new dizzy only a week or 2 old...
Old Jan 25, 2013 | 12:59 PM
Default Re: still cranks no start
also i had a chip which had eld disabled didnt realize right away... but car ran (only took it around the block a few times) let the car sit for a few months and it wouldnt start, fixed my engine wiring harness some how wiring now wasnt connected to iat, iacv, tps and injectors( but it was running fine before) re did the engine harness and all the sensors and injectors work correctly!!!!! and put in a different chip(type r program w/ eld enabled) was wondering if having the eld off for a short amount of time could cause damage to something else??? NO CHECK ENGINE CODES COMING ON...ecu seems to be working correctly but car still cranks but wont start... its really starting to **** me off.... HELP!!!!!
Old Jan 26, 2013 | 03:04 PM
broncoman74's Avatar
From: Northwest Hills of, CT., United States of America
By chance have you tried replacing the "Main Fuel Relay"? search on the forums here. It is a common problem with no starts. It cost me about $75.00 to have the dealer replace it about 10 years ago. You can do it yourself but I am sure there is a "How To" tread on here somewhere.
Old Jan 27, 2013 | 01:44 PM
i have a brand new one didnt reswap it in since i re did the wiring,but it cant hurt. i tested both and they were working fine.... but im gonna do that frst thing 2morrow.thanks for the reply
dajuice_8
Jun 17, 2014 05:55 PM
raider1qaz
May 14, 2014 05:55 PM
punkkid12o3
Honda Civic (2001 - 2005)
Sep 17, 2008 03:22 AM
rEdLiNeObSeSsOr
Jan 28, 2008 01:00 PM
aznej2
Sep 1, 2006 11:56 AM
