MA 1993 Toyota Supra Turbo - Single Turbo, CCW's, 750whp!
1993 Toyota Supra.
Original 6 Speed Twin Turbo & Targa Top Car
103,000 miles
Price : Asking 34,900 *or see bottom
Phone: 508-567-8748
Email: bigbadtim1137@aol.com
I am posting up my Supra for sale, because I am considering moving onto bigger things in life. I have spent the past 2 years bringing this car to what it is today. The car is well sorted, turn key and ready to go. Has good working air conditioning and runs like a top.
The car is Renaissance Red and an original twin turbo 6 speed car, no conversions like alot of the cars out there. 98 spec tails were added, along with the euro glass headlamps. Everything else is pretty much listed below in my mods list, but Ill go over the basics. The car has polished 18" classics now, HKS Hipermax coilovers, and a complete single turbo setup and fuel system. The motor has also been freshly rebuilt, ( cp, eagle, hks cams etc. ) details of the motor build are listed below. I decided to go with the PTE 6766 for the ultimate street setup, mated with an RPS manifold and an HKS Carbon-ti exhaust, the sound this car has is absolutely exotic. Below is a complete list of mods.
The car was tuned by Alex Wohlwend owner of Granite State Dyno The car made 509 whp @ 17 psi on pump alone, and 559 whp @ 23 psi on pump + meth. With more boost, the car will do 750+ horsepower on C16.
Performance / Engine
Engine
Built 3.0 2JZGTE
CP pistons 8.5:1 compression
Eagle Rods w/ Upgraded 2000 bolts
ACL Race bearings
ARP Mainstuds
Modified Oil pump
Titan Billet timing belt tensioner
new timing belt and components
All new gaskets (obviously)
New valve stem seals
New oil cooler
Machine work on block ($3000 in receipts for machine work and assembly labor alone!)
Cylinder bore + hone
Crankshaft main journal line bore
Crankshaft journal re-grind
Main and rod journals measured
Block sonic cleaned
Block deck resurfaced
Block full assembly
Cylinder head bead blasted
Cylinder head deck resurfaced
3 angle valve job
New stem seals installed
Cylinder head assembly and re-shimming for HKS cams
Other Engine performance stuff
HKS 264 cams
ARP L19 Headstuds
AEM V1 Standalone Engine management
AEM Intake Temp sensor
AEM 5 BAR MAP sensor
AEM Methanol Injection system w/ Dual nozzles
HKS DLI Ignition Amplifier
Brand New Toyota OEM Ignition coils
TRD Engine Mounts
TRD Transmission Mount
HPF Clutch
-10AN Catch Can Breather setup with Full Blown black/purple Anodized Fittings
PHR Polished Upper Radiator Pipe
PHR Lower Radiator Hose Rotator
TRAC system delete
Welded Upper Waterneck
Turbo setup
Precision T4 Turbo 6766 Billet milled wheel. Dual Ball Bearing. 0.82 Turbine housing
Boost Logic -AN Feed and Drain Lines
Original RPS Turbo Manifold. Modified to accept two larger wastegates
TiAl MVR 44mm Wastegate anodized purple x2
TiAl Q Blow off valves x2
Greddy 3 Row Intercooler
Greddy Profec B-II Electronic Boost Controller
4" Intake with K&N Filter
4" V-Band Downpipe / Midpipe
HKS Carbon Titanium Exhaust
Fuel System
Dual Denso Fuel Pumps
Two -6AN Feed Lines
Two Fuel Filters (Toyota and RedHorse)
Fuelab Fuel Pressure Regulator
Fuel Injector Clinic Fuel Rail
Fuel Injector Clinic 1050cc Injectors
Entire fuel system converted to -6AN braided line with blue/red anodized fittings
cosmetics
Polished Turbo Compressor Housing
Polished Upper Water Neck
Polished Intake manifold
Polished Throttle Body
Polished valve Covers
Polished Intercooler Pipe
Polished Intake pipe
Exterior / Chassis / Suspension
HKS HiperMax II Coilovers
Toyota OEM European Glass Housing Headlamps
Toyota OEM 98 spec Taillamps
New Toyota OEM Emblems
New Toyota OEM weather seals
Paisley Carbon Fiber front lip
Sparco Aluminum Gas Door
Titan Motorsports Billet Differential Ear Mounts
Titan Motorsports Solid Rear Subframe Mounts
Wheels / Tires
Full Polish CCW Classics w/ ARP hardware
Front: 18x10
Rear: 18x11.5
Front Tire: Advan 285/35/18
Rear tire: New Toyo R888 315/30/18
Interior / Entertainment
AEM Methanol Injection Controller
AEM Wideband gauge
Autometer Cobalt Electronic Fuel Pressure Gauge
Autometer Cobalt Electronic Oil Pressure Gauge
Autometer Cobalt Mechanical Boost/Vacuum Gauge
LED Warning Lights for Fuel Pumps and Meth Injection
Pioneer AVIC D-2 In-Dash Navigation Unit
Pioneer Rear 6.5 Speakers
Toyota OEM Rear Subwoofer
I am in absolutely no rush to sell the car. I own the car with title clean and clear. Title is clean as well all VINs present. If you see the car, and want a Supra this car is well worth the money. More pictures are available upon request. I take immaculate car of my cars, this car receives a Brad Penn oil change every 500 miles with OEM Toyota filter.
*Willing to entertain trading for cars of lesser value + cash, such as S2000, CR-Z, STI, EVO, etc. NO civics, integras, rsxs, or highly modified cars.
103,000 miles
Phone: 508-567-8748
Engine
Built 3.0 2JZGTE
ACL Race bearings
ARP Mainstuds
Modified Oil pump
New oil cooler
Block sonic cleaned
Block full assembly
3 angle valve job
HKS 264 cams
ARP L19 Headstuds
TRD Engine Mounts
HPF Clutch
TRAC system delete
Turbo setup
Fuel System
Two -6AN Feed Lines
cosmetics
Wheels / Tires
Front: 18x10
Rear: 18x11.5
AEM Wideband gauge
Thanks for all the kind words, hopefully someone here will be interested.
Id consider trading plus the remainder in cash for another newer Honda like a CRZ, or a newer Si or RSX etc. Im just looking to get out of modifying cars.
dirtyharryhatch
Feb 15, 2012 08:05 AM
bangin'gearz
Mar 8, 2005 05:56 PM
iBrandon
Sep 2, 2004 01:25 AM
