2.25 to 2.5 catback exhaust
My exhaust has rusted through in many places including the flex pipe. Instead of replacing it all with stock, I am going to just get a catback exhaust. I found one through spec-d tuning, but it is 2.5 piping. Will the flanges on that, bolt up to my catalytic converter? Or will I need to modify it to work? I know that spec-d isn't the greatest choice, if anything I will cut off the muffle on it and weld on a new one. Also if anyone has any tips to make the hangers work if they don't line up, that would be great. Thanks!
1995 Honda Accord EX sedan
(Soon to be more awesome)
most of those ebay exhuasts are not a true 2.5....some are really a 2.25 and some are a 2.5 outer diameter but are really 2.36 inner diameter
there is no way of knowing if it will need modification but if its like the ebay-type exhaust i had then it shouldnt
Most of the hangers will line up, you might have some rattling with the heat shields. But your cat should line up, at least mine did. I had my axle back portion modified to clear the right rear control arm because it was rubbing and I had a Megan muffler welded on.
