Come and watch my DC4-1 header own me
Old Oct 20, 2002 | 07:10 PM
ScottEK's Avatar
Default Come and watch my DC4-1 header own me
I have a major problem, it all started with buying a DC4-1 header, great header in my opinon. Luckily I was doing a swap at the time so installation was a breeze. At the time I would have never thought that I want something faster, well I do. No I have this huge one pipe in probably stuck in my car. How am I going to get the header out, it currently is resting ON the crossmember. Is there an easier way to get this header off than removing the engine? If you haven't guessed, I'm going turbo and will be switching from a DC 4-1 $300 header to a 1989 CRX HF $30 header, seems logical right?
[Modified by beta13, 10:11 PM 10/20/2002]
Old Oct 20, 2002 | 07:13 PM
USDM 4G VTEC's Avatar
Default Re: Come and watch my DC4-1 header own me (beta13)
u need to loose the crossmember in order toi take the 4-1 header out.....
Old Oct 20, 2002 | 08:14 PM
ccjb100's Avatar
Its really not that bad man. I actually had to put my 4-1 on my B16 after it was in the car. Just take of the dust shields that cover the front crossmember. Take the front wheels off so you can reach and undo the two bolts that attach each radius rod to the lower control arm. After that it's only 4 more bolts (2 at each end of the crossmember) and the whole crossmember with radius rods attached will drop off the car. Should give you plenty of space to drop the header out from the bottom.
Old Oct 20, 2002 | 08:35 PM
ScottEK's Avatar
Default Re: Come and watch my DC4-1 header own me (ccjb100)
I'm saved, thanks.
prejdmlude
Nov 11, 2006 01:28 PM
98vtec
Welding / Fabrication
Mar 17, 2005 06:37 PM
JDMlyfestyle
21
Jul 5, 2004 07:53 PM
ImporttRacerr555
Nov 25, 2003 02:13 PM
ITR 01-0840
Apr 25, 2002 05:01 PM
