94 accord w/ h23 swap help
I just bought this accord and it has been swapped over to a h23, and whoever did it put some weird mount on the drivers side and im looking to replace it, which mount do i need? Prelude or accord?
Mounts-
Rear-Front-Passenger side Accord Mounts
Drivers side Prelude Mount (will need slight grinding to fit)
make sure you get the mount from a 92-96 prelude
Prelude 92-96 engine mount on the nearside and an Accord mount on the Offside. Apparently Prelude mount needs slight trimming but. Anyway, not-so-cheap shiny mounts below...
http://hasport.com/store/index.php/m...3rgemars1v1g42
Sounds like the shift linkage... https://honda-tech.com/forums/honda-prelude-4/shift-linkage-problem-2790234/
hmm, all the gears are where they should be, its nothing like that, though when the clutch does actually disengage the pedal is less than a quarter inch off the floor....
Hmm I got no idea then sorry, this is my first Honda and only got it last week. Shift linkage was the problem in my old mk4 Golf/Rabbit and it sounded like the same symptoms. Sorry mate.
check for master leak on your interior fire wall fluid would soak into the carpet and if you slave is bad squeeze the boot to see if fluid comes out if it. if you like me and dont like problems down the road replace both at the same time
pinecone
May 12, 2007 07:30 PM
H23preludeSi
Apr 20, 2004 08:17 AM
