PWR and Fluidyne Radiator Owners: Need info on fans
where did you find information on where to buy fans for the pwr and/or fluidyne radiator? i need to run a/c as well, so I will need two fans. to my knowledge the radiator is a bit thicker than stock fans, and will require the aftermarket fan.
where can I get information on installing the fans, and where to obtain the fans and other equipment needed?
thanks in advance.
thanks in advance.
i used the stock fans on the fluidyne radiator. i had to buy a fan mounting kit from an auto parts store because the radiator for the ls doesn't have a place to mount the a/c fan. i mounted them on the inside like it comes stock and had plenty of clearance. of course when i get the turbo, i will have to mount the a/c fan on the other side to clear the turbo manifold. hope that helps.
4doorH22
Jan 19, 2002 12:12 PM
