94-97 accord motor mounts
hey i have a 94/95 honda accord with a f22b1 motor in it.
im confused as to what to get bc my accord use to be an automatic and was converted to a f22b1 5 speed before i got it.. so im not sure if i need bc once i get the mounts, im swapping the f22 trans out for a h22 lsd 5 speed trans
its either: "ESP CD 94-97 Accord H/F and 97-99 Acura CL F22/F23 Models Auto to 5 spd (Conv.) Motor Mount Kit. Auto to 5 spd Motor Mount Kit with F22 Motor" or do i need "ESP 94-97 CD Accord H/F 5 spd Motor Mount Kit"
btw its a 94 accord wagon lx with an f22b1, 5 speed converted already before i bought it. im installing a h22 lsd 5 speed transmission after i get the mounts
http://www.explicitspeedperformance.net/ESPHAMMK.html
thanks for your help!
I was unaware the the fifth gen accords came with anything other than the F22b1 or B2. All you should need its the stock mounts for that year accord.
Posted from Honda-tech.com App for Android
When I did my 5spd conversion I had to drill out the upper dimple on the motor mount bracket (chassis side). Then you would just use the normal 5spd mount or set of 5spd aftermarket mounts. If yours isn't already drilled you could drill it and use some OEM or aftermarket mounts.
BlaccPlasticc
Aug 29, 2013 12:49 AM
Civichatch2k
Aug 9, 2003 04:55 PM
