Need Ecu Pinouts for d16y7 IACV. Idle Air Control Valve
Just need to know where the 3 wires from a d16y7 Idle Air Control Valve go to which ecu pinouts. Civic is a 98 (OBD2a) Reasoning below:
I recently bought a 98 Civic Ex that has a d16y7 engine with a y8 intake manifold, y8 engine wiring harness and a y8 ecu. Check engine light was on because it didn't read a vtec solenoid because there isn't one there.
In order to get rid of the CEL, I'm installing a y7 ecu and a y7 throttle body which uses a 3 wire Idle Air Control Valve. I need to know where the wires on the IACV plug go to which pinouts on the ecu.
Forgot to mention the IACV plug has the following color wires: Orange, Yellow/Black , and Black/Blue
I found on FFsquad that the orange wire most likely goes to pin A13. Just looking for the remaining 2.
Here's a link with some more info: http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg
hey did you ever figure this out im doing this exact thing right now and if you found the pin out or know it and could write it down that would be awesome
Hoopdie91
Feb 18, 2018 04:39 AM
esurds
Jun 8, 2009 04:12 PM
