Is this block sleeved?
Old Jan 24, 2013 | 09:21 AM
ceearexx's Avatar
Default Is this block sleeved?
I was just wondering if they look like sleeves to you guys? He is selling it for 200$ obo but he didnt state if they were sleeves or not.
Old Jan 24, 2013 | 09:25 AM
JuggerNaut-CTR's Avatar
Default Re: Is this block sleeved?
Looks like stock sleeves if thats what your asking...
Old Jan 24, 2013 | 09:50 AM
darnizzle8805's Avatar
He had a block guard installed, Stock sleeves
Old Jan 24, 2013 | 09:56 AM
slowturbocx's Avatar
Looks like a Nuformz block guard.
Old Jan 26, 2013 | 12:28 AM
kreeg.b's Avatar
arent block guards harmful ?
Old Jan 27, 2013 | 05:05 AM
93geezr's Avatar
Block guards rob the cylinder head of proper cooling. This can lead to pinging (knock) and KA-BOOM!!!
I would avoid this block like the plague if the guy is telling you it's sleeve. Chances are he's stupid and doesn't know what he's saying or
a crook trying to take you for a ride and your hard earned cash. Good luck mang.
Old Jan 27, 2013 | 07:46 AM
Eg.ls.turbo's Avatar
Never had a block guard installed on my motors don't like them really. But u can pull it out and still use the block if its still good
Old Jan 27, 2013 | 09:40 AM
GhostAccord's Avatar
Block guards are only harmful if they are installed improperly or of a poor quality.
They will not rob the head of cooling if there is a 1/4" to 1/2" space left between the cylinder head surface and the top of the block guard. Also as long as there are a sufficient number of ports in the guard to allow the flow of coolant from the bottom of hte block into the head. In this respect this install looks to be good.
The other way that a guard could be harmful is if the cylinders are forced out of round or shifted due to the install. this can be checked and fixed a machine shop.
As far as wondering if the cylinders are sleeved or not. If he didn't state that they were, they probably aren't.
Other than that it's hard to tell in those pictures. They could have a set of dry sleeves installed. You would have to measure the OD and ID of the iron sleeve liner. And see if they match ether the OEM or a sleeve manufacturers specs.
Old Jan 28, 2013 | 05:11 AM
93geezr's Avatar
My experience with them comes from my friends who ran them in their set-ups and encountered cooling and pinging issues.
I guess that would make sense, but I honestly wouldn't run them.
Old Jan 28, 2013 | 01:04 PM
I wouldn't personally run them ether. However, I have installed them in other peoples engines and after a proper install and block check. There have never been any over heating or pinging issues. Sounds like installer error or a tuning issue.
Darton MID sleeves use a an integrated deck (similar to a block guard) and they have 0 cooling issues.
Old Jan 30, 2013 | 03:48 AM
seelback's Avatar
if installed properly on and properly put together setup and tuned properly, you shouldnt have any issues. highly recommend using a golden block guard, like ghost accord said, have the machine shop check the cylinders. my tuner made 700whp with a g.e. block guard on a stock sleeve b20.
Old Jan 30, 2013 | 11:09 PM
93geezr's Avatar
I'm doubtful of that last part you said, but anything is possible I guess. Any way of proving this?
Old Jan 31, 2013 | 06:02 AM
neophish's Avatar
yea, and my CRX has a d16 in it with 800 HP all motor...
Old Feb 1, 2013 | 03:49 AM
seelback's Avatar
i will se if he will post a pic and video. stock b20 sleeves are stronger then you think.
Old Feb 2, 2013 | 07:13 PM
PhilStubbs's Avatar
I'd love to see the proof. There is no way a b20 made 700 on stock sleeves. Maybe, and this is a stretch, but it might be possible with the cncwerx CSS.
TravisBiggie
Oct 18, 2013 05:08 AM
Boosted_EG8
May 9, 2009 12:12 PM
marksturboek
Apr 23, 2006 03:02 PM
sodacan33
May 2, 2004 05:53 PM
Twenty36_1
Aug 14, 2003 12:32 AM
