I cant freaking get the bolt off of my fuel filter!
Old Oct 20, 2002 | 06:38 PM
Andrew 825SM's Avatar
Default I cant freaking get the bolt off of my fuel filter!
When changing your filter, did any of you guys have a lot of trouble getting the bottom bolt of the fuel filter which is connected to the hard fuel line. I'm using a 14mm wrench to try to get this thing off and the damn thing just wont budge!!
Old Oct 20, 2002 | 06:39 PM
sutrusu's Avatar
Default Re: I cant freaking get the bolt off of my fuel filter! (NHB Fighter)
have u tried breaker bar + pipe?
Old Oct 20, 2002 | 06:52 PM
Eluzion's Avatar
I just did mine today and it was a pain in the ***. Just kept trying, and trying, and trying... and finally it came off.
bmm89's Avatar
Default Re: I cant freaking get the bolt off of my fuel filter! (sutrusu)
wrench on top and wrench on bottom
Old Oct 20, 2002 | 07:17 PM
zojirushi's Avatar
Default Re: I cant freaking get the bolt off of my fuel filter! (bmm89)
damn and i need to change my fuel filter soon too
Old Oct 20, 2002 | 07:29 PM
B18EG6's Avatar
yeh mine was a lil fack to get off too...dont forget to use the brass washers on the top when you get the new one!
AB16A2T's Avatar
Default Re: I cant freaking get the bolt off of my fuel filter! (zojirushi)
I finally got my axle nuts off, those were a pain the frigging ***... Bent the crap outta the breaker bar and the big *** 1/2 driver I got instead of the normal ratchet...
Old Oct 20, 2002 | 07:31 PM
95GS-R's Avatar
Default Re: I cant freaking get the bolt off of my fuel filter! (AresB18BTurbo)
Yes ... it sucked. I cut my pinky finger open when the wrench slipped. But, I got that bastard off. Keep at it, it will give.
Old Oct 20, 2002 | 08:52 PM
Default Re: I cant freaking get the bolt off of my fuel filter! (95GS-R)
I give up! The bolt is rounding off. I think I turned it the wrong way and stripped the bolt...I forgot you have to turn it the opposite direction since the bolt is facing downwards. I tried to turn it the other way and the damn thing is stuck like no tomorrow. The band on the filter is also beginning to break loose. Guess I'm off to the Acura dealer tomorrow.
[Modified by NHB Fighter, 10:02 PM 10/20/2002]
Old Oct 20, 2002 | 08:56 PM
Eluzion's Avatar
Damn, sorry to hear. Was just about to post about that (make sure you're turning the correct way) but looks like it's too late.
Old Oct 20, 2002 | 09:00 PM
AB16A2T's Avatar
Well you could always get new bolts from the dealer tommorow, and use a vise grip on the ones you have on just to get them off after you pick up the new ones...
Old Oct 20, 2002 | 09:17 PM
echo999's Avatar
New User
Try this... get one of those visegrips.. clamp down on it real good, then use a hammer..
works well when there's nothing left for your wrenches to bite down on.
Old Oct 21, 2002 | 03:29 AM
Honda4CX-T's Avatar
You are not suppossed to use a regular wrench, instead you should have used a FLARED Wrench (Used for A/C and Fuel line couplings). I know it's a bit late to tell you now if you've rounded off the couling though.
[Modified by Honda4CX-R, 7:30 AM 10/21/2002]
Old Oct 21, 2002 | 04:46 AM
Ubermensch's Avatar
Default Re: I cant freaking get the bolt off of my fuel filter! (Honda4CX-R)
It doesn't matter what kind of wrench you use if you turn it the wrong direction.
Old Oct 30, 2002 | 08:36 PM
95GS-R's Avatar
Default Re: I cant freaking get the bolt off of my fuel filter! (Ubermensch)
Agreed ... I didn't have any fancy wrenches. I was using the cheap kind that you buy at K-Mart and self adjust. You know, the one that changes grip right when you just got it lined up ...
Old Oct 30, 2002 | 08:49 PM
Arturbo's Avatar
Better than steak
25 Year Member
Yup, he is exactly right. A regular open ended wrench wont work. Snap on sells them and they are called line wrenches, or you can go to sears and get the flared wrench. You should still be able to get it off if its semi-rounded.
art
lsvtek
May 21, 2007 08:29 PM
95lscivic
Apr 18, 2007 10:21 PM
SexyAzNMami
Nov 19, 2004 12:00 PM
blackeg
Oct 27, 2003 04:38 PM
Pat
Jan 1, 2003 07:40 AM
