Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
aspec sideskirts
Old Jan 23, 2013 | 02:10 PM
grnaccord's Avatar
Default aspec sideskirts
I have a 03 civic ex and want to put some aspec side skirts on it. My question is are the eBay ones the one everyone uses. Also how do you mount them? Do they screw in at each end or what? Any info will help than.
Old Jan 23, 2013 | 04:26 PM
jmvtec05's Avatar
Default Re: aspec sideskirts
The Type A skirts? idk of aspec but yes, a good chunk of us get them from ebay... some kits come with hardware for the bottom and some don't come with any hardware at all. haha. I know Jake (OBK) just has screws at the end of each side. that, and 3m double sided tape to hold it in place.
Old Jan 23, 2013 | 10:17 PM
JKulet's Avatar
What I did was. You can get some strong glue. I used Urethane glue. Get some metal screws. Two people would be nice. For permanent side skirt and painted. Alot more extra work than tape.
First test the side skirts fit. ***
check how you want to place it.
Put nice even layer of glue on sideskirt on the top where it will stick to the panel. On sides if needed.
Put some metal screws on each side.
Put some along the top so the skirts so it will have proper contact.
Let it dry fully. Grind the top of metal screw. Fill in with body filler/fiber glass filler.
Sand nicely. Paint.
Permanent Side Skirts.
Some extra work but for me is better cause after the stupid double sided tape started to coming off. I ended up breaking my side skirt some how by hooking/stepping my foot on it while getting out.... Stupid plastic.
Posted from Honda-tech.com App for Android
Old Jan 24, 2013 | 04:50 AM
grnaccord's Avatar
So do they sag in the middle if you just screw them in on each end?
Old Jan 24, 2013 | 10:14 AM
jmvtec05's Avatar
They might sag a little but if your sides come with hardware, just bend the bracket to where the side skirt still sits how you want it to sit. Basically, its the brackets for the bottom that leave it flaring out a bit. Some like it, some don't. I personally don't but i haven't had the time to somehow make it work.
Don't know if you can really see the flare but this is what you get if you use the brackets for the bottom (if you get any, at all)
I've ordered 2 sets and 1 came with hardware, one didn't.
Name:  xxr chrome.jpg
Name:  My em2 dr20s.jpg
All of these pics are with the brackets, which I still have on. Its not much, but it does bother some.
Old Jan 26, 2013 | 07:48 AM
grnaccord's Avatar
I think it looks good. Did you order yours off eBay?
Old Jan 26, 2013 | 01:24 PM
Zedt3's Avatar
Where did you guys order those skirts? I'm looking for some as well for my em2.
Old Jan 26, 2013 | 01:29 PM
jmvtec05's Avatar
They're all over Ebay bro.. that's where I got mine. No problems
Old Jan 26, 2013 | 03:41 PM
Zedt3's Avatar
I have tried searching for aspec skirts for 2001 civic etc...and still not seeing the ones you guys have pictured above. What do i look for?
Old Jan 26, 2013 | 07:10 PM
jmvtec05's Avatar
No, No, No...
They're not called "aspec" You need to search Type A or simply just 01 honda civic sideskirts. They're called something else by different companies. Type A, Type S, Rs...etc
Here: http://www.ebay.com/itm/01-05-Civic-...3365c3&vxp=mtr
farkiller
Aug 23, 2009 01:09 AM
LaEzEnT
Apr 23, 2007 08:08 AM
95si
Nov 24, 2002 07:19 PM
VTEC-DA
Oct 14, 2002 12:27 PM
Phat_GSR
Sep 7, 2002 01:31 PM
