Squeaking relay. Nostart no crank
I have a 2005 honda civic that is not starting or cracking. When attempting to crank car a relay buzzes.
I checked all grounds and they are all solid.
Replaced relay and same issue occurs
Any ideas?
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/
Did this. Starter will jump. Car starts if I jump starter.
When attempting to start the car the starter terminal shows 0 volts
From starter big wire gets 12 volts. Little wire to terminal gets 0 volts. Tested fuse box inside car. The relay spot is getting 12 volts when the key is turned
Any ideas?
Schultzie
Jan 23, 2013 09:46 PM
vladiscoolej1
15
Oct 23, 2010 06:55 PM
