Jdm-r question
Old Jan 22, 2013 | 11:32 PM
Ej2beast253's Avatar
Default Jdm-r question
Hey, I just got a jdm-r (b18c) short block, if I slap a b16 head on it and get I/h/e can I expect the same numbers as a full b18c swap?
Noob question I can't find any answers on line lol
Old Jan 23, 2013 | 12:56 PM
allmotordc2R's Avatar
Default Re: Jdm-r question
i dont think you would get the same out of it a type r head flows better
Old Jan 23, 2013 | 07:47 PM
racebum's Avatar
if you can find one that's actually in good shape or get one and do a valve job then yes. the early 96 engines had no port work at all. the later hand blends and later still cnc jobs were basically bowl blends. if you have a die grinder and 45 minutes you can do the same amount of port work yourself.
if you have the engine this far apart it's not a bad idea to pull the pistons, measure the cylinders for out of round, if all is good, rehone with a mild, say 320 grit ball hone and install new rings on the pistons. with miles, age and heat cycles rings drop in tension. honda used lower tension rings on the R to start with and many burn some degree of oil because of it
Old Jan 23, 2013 | 11:22 PM
Hey, so today I bought a b16a sir-2 head with gsr cams. What can I expect?
And what ecu would you guys run? I drive a odb1 ej2 civic 2door.
Am I even posting in the right section? I've never posted on Honda tech.
^i expect to get a tune within a month of swapping out my **** Ls for this type r swap
Old Jan 24, 2013 | 02:57 AM
NemesisCBR's Avatar
Expect less performance out of it with those cams. If i were you id upgrade to itr cams or something appropriate for your build if you have a goal in mind. Think valve train required per your cam choice.
Old Jan 25, 2013 | 02:56 AM
Motors going into the car this weekend ill let you kno how she runs.
b18c1hatch1992
28
Apr 8, 2021 09:03 PM
SilverEk3dr
Apr 30, 2009 07:53 AM
RdEcD2
15
Oct 27, 2006 12:35 PM
b18cTurbo
Dec 19, 2001 11:41 AM
