Question about Altenator.
So I did research cause my battery light came on and stayed on, I read that it's a sign that Altenator is going bad..what else I read
belt loose.
alternator bad
battery going
question is to take off the Altenator it's only 2 bolt, adjuster bolt on top and the bottom bolt.... right?
Asking cause its 12 degrees outside so wanna be sure before messing with it
belt loose.
alternator bad
battery going
belt loose.
alternator bad
battery going
belt loose.
alternator bad
battery going
MM&Y of car????
What Coopa B18c5 said, take the car to any batt. shop and have them check the cars charging system and batt., it will be free, it takes a few min. 94
just a little input, i just took mine off for the second time it makes it a little easier if you take the oil filter off. gives an extra 3 inches or so to wiggle with. had a hard time before i took the filter off.
beyondspexj
Apr 20, 2006 11:04 PM
nighthunt6
Nov 29, 2001 01:37 AM
