H22 gearing
Old Oct 20, 2002 | 06:20 PM
lazy bum shaughn's Avatar
Default H22 gearing
What is the code for the H22 tranny? But my real question is, what MPH do you guys redline in each gear?
Example: first gear redlines at 40MPH, second gear redlines at 65MPH etc.
Thanks.
Old Oct 20, 2002 | 06:54 PM
satan_srv's Avatar
Default Re: H22 gearing (Breakdancer)
Which tranny? Which year?
97-01: M2Y4
93-96: M2F4
Old Oct 20, 2002 | 06:56 PM
Default Re: H22 gearing (satan_srv)
H22 trannies, both generations I guess. Is it a big difference?
Old Oct 20, 2002 | 07:26 PM
satan_srv's Avatar
yeah there's a fairly noticeable difference.
from http://prelude.vtec.net/gen4
M2F4 - 4th gen
1st 36mph
2nd 61mph
3rd 88mph
4th 112mph
5th 135mph
Old Oct 22, 2002 | 11:19 AM
MPower332TI's Avatar
i just noticed that thing said 6.2 qts of oil...wtf??? how much oil ru guys running...i run right at 5....let me know..thanks...
Old Oct 22, 2002 | 11:24 AM
satan_srv's Avatar
Default Re: H22 gearing (jDmDxTuRd)
It's actually 4.8 litres...I don't know why that says 6.2 quarts...unless my conversion is off
Old Oct 22, 2002 | 12:04 PM
Boostless97Lude
Guest
Posts: n/a
i've never hit the rev limiter in 5th gear, other than that, it's been to damn long since i drove it, oh yeah, and when some ******* wants to race from 60mph, don't do it.... top of 2nd gear, bottom of 3rd, not a good place to start pulling, especially since you can get up to ~90mph in 3rd.... it's a good long gear
Old Oct 22, 2002 | 12:06 PM
DarkJedi's Avatar
my tranny code is M2B4
Old Oct 22, 2002 | 12:13 PM
satan_srv's Avatar
Default Re: H22 gearing (DarkJedi)
4th gen tranny with LSD. Available only on JDM H22a's same ratios as M2F4
Old Oct 22, 2002 | 12:22 PM
bgod's Avatar
an h22a1 tranny will roughly go 80mph in 5th gear at about 4200-4400rpm on the stock tach. stock tach being key. just for reference.
on my old accord with an h22a1 tranny and h22a4 motor.
i hit the rev-limiter in 5th gear. on the stock speedo the mph read roughly 140-142mph. the tach was bouncing off 8000rpm.
this was during a top end run which i lost because of the revlimiter and gearing.
Old Oct 22, 2002 | 02:34 PM
TrboH22's Avatar
Default Re: H22 gearing (bgod)
5th gear hitting rev limiter for me was 152 MPH Indicated...I'm almost positive it's not actual...speeds that high can't be perfect..
Old Oct 22, 2002 | 03:15 PM
ichibanjap's Avatar
Default Re: H22 gearing (TrboH22)
My 4th topped out at 126. While shifting to 5th my fuel cut off came, and i couldn't go any faster.
Old Oct 22, 2002 | 05:00 PM
LudeSpeeds's Avatar
I was raceing a friend on the freeway out here in Cali, doin a buck 30 (thats 130 mph) at like 7 grand. My redline is at 7400 and my limiter is at 7600. I haven't gotten another chance to try it but, I've been told that you hit the limiter around 135 to 138 depending on whether or not your on flat ground. My plan is to just put in a Lude SI or Base model (of about the same year) 4th and 5th gear in my tranny. I plan to do this just for the gas mileage because I can't stand being at 4200 at 80 mph.
Old Oct 22, 2002 | 09:04 PM
kb58's Avatar
Banned
Default Re: H22 gearing (LudeSpeeds)
Don't forget to figure in tire diameter. Many have installed oversized tires to some degree, which will both give you a lower than actual mph, plus lower your top speed because of the lower torque available for pushing the air out of the way.
maddmatt02
Sep 19, 2010 09:09 PM
TreWatts
Feb 5, 2008 04:01 PM
.BigSexy
Sep 26, 2005 05:16 AM
Mighty Mintos
Dec 29, 2002 10:35 PM
