93 del sol smells rich replace several parts
ok here goes AGAIN 93 del sol started out was getting hot under my feet then shop tell me i need converter i replace converter thing still smell like rotten eggs with the brand new converter . coolant temp gauge was stayiing on the c mark and not moving asked here people said change t stat change t stat gauge now working properly . still smells rich some one advise maybe a coolant temp sensor tried that still smells rich . no check engine codes . This is my girlfriends car and it driving me F#@%! insane with her complaining every day Some body with any info that may help me before there is a dismantled del sol on the way to the salvage yard lol. could it be a leaking injector ? i do9nt hear any exaust leaks what so ever . Oh by the way i am a mechainc of 20 =+ years and this car is as easy to work on as they get . maybe i trade her in instead
I assume you're smelling gas fumes?
The fuel pump access in the del sol is under the plastic panels behind the seats. Maybe there is some fuel leak around the pump seal in the top of the gas tank.
Maybe the fuel filter has a leak? (Under hood by firewall)
If you're smelling burning oil fumes after being driven than maybe what you are smelling is an oil leak from the passenger side of the engine main oil seal leaking on to the hot exhaust pipe. This leak doesn't always get to the ground.
I have a 93 & 94 del sol. They also smell like mold from the leaking roof seals.
