800hp turbo car part out
Im parting out my Integra anything you need lmk.
1994 acura integra GSR tags paid this car is registered
Clean title
Registered
Mb products one piece front end clearanced for 26x10 wheel/tire setup
Custom made traction bar from steen chassis tied in to the frame
Custom front mount like full race with flate and rod with heims
12 point roll cage needs to be certed
17 inch Kirkey drag seat adjustable sliders SEAT AND BRACKETS NOT INCLUDED
Seat belt hoops on cage behind seat NO BELTS INCLUDED
Custom intercooler crash bar with tabs for intercooler
Strange quick release with adapter from 5 bolt to 6 bolt steering wheel
Hardware for HVC2 Coil is still on fender well
Fiberglass doors unknown brand
Lexan throughout the car
Aero latch on both doors to prevent from ripping off
Custom door handle on both doors for ease of access
Stock hatch with lexan
Rear bumper oem just cut for air flow
New slave cylinder
New clutch master cylinder
Metal sunroof plug
Wing just added with custom supports
Wiring harness with switch panel never had any issues
Stock fuel tank sumped and coated inside and out to prevent rust
Suspension:
Function form type 2 shocks dampening $675
Energy suspension bushings on the front lower control arms and shift linkage
ITR Rear Disc 4x114 with Energy Trailing Arm Bushings $175
Skunk2 rear lower control arms $100
rear camber kit $75
Omni front camber kit $100
Extras:
Innovatibe Solid billet motor mounts $275
Intercooler:
Water to Air intercooler good for 1200hp $450(with pump and lines)
Bosch Cobra Water Pump
-10 water lines
$7500 OBO FOR THE SHELL WITH EVERYTHING ABOVE LISTED.
Engine:
LS RS Sleeved 82mm block no crank oem water pump 2 -10 fittings on back of block z10 oil plug arp main studs all head studs, half shaft, and trans bolts have been time serted. no oil pump $875
Arias Pistons 9:1.0 they are used basicaally your paying for the hd pins and new rings $175
Crower Steel Billet Rods $525
Moroso oil Pan $150 with fittings 140 without fittings
ARP Head Studs $60 torqued twice
Water Pump $35
Timing Belt $35
GSR Head with Flat Face Valves and Supertech Valvetrain $800
Skunk2 flush mount valve cover kit gold $65
Oem gsr dizzy with msd cap $160 with duesch connector both ends
Ngk wires $35
Fuel:
Aem fuel rail $85 no fittings
Aem Universal Fuel Pressure Regulator $110
Cooling:
Koyo radiator $175
Fal slim fan $150
Trans:
B16 trans has ls final drive NON LSD $650
Wheels:
Weld draglite wheels 15x9 mustang bolt pattern
Mickey Thompson 26x10x15 et drag slicks
Axles:
Mark Williams axles, halfshaft, spool, spindles, four piston brakes $3600 will include wheels for this setup with slicks
Turbo Kit:
Hnh topmount turbo manifold T4 with V60 wastegate flange $750 obo
Hnh 3 inch downpipe with custom hanger and 02 bung $150
GT4094R Dual Ball Bearing T4 Turbo with .96 AR Hoside
ALSO HAVE
CRX SI FRONT SEATS
JDM FRONT END FOR CRX
Chuck
310-977-1201
Clean title
Registered
New slave cylinder
Metal sunroof plug
Suspension:
rear camber kit $75
Extras:
Intercooler:
-10 water lines
Engine:
Water Pump $35
Timing Belt $35
Ngk wires $35
Fuel:
Cooling:
Koyo radiator $175
Fal slim fan $150
Trans:
Wheels:
Axles:
Turbo Kit:
ALSO HAVE
CRX SI FRONT SEATS
Chuck
310-977-1201
