I need some ideas
Your project will actually all depend on what you intend to do with that ride. If daily driver with a kick, Niles' ideas are good. But if you want a street beast, consider a low boost turbo kit, unless you plan to build up the cylinders to withstand higher combustion then you can go with a higher boost turbo. But like I said, it all comes down to what you plan to use the ride for...
check out MRT's if you don't know what mods to start with. Otherwise I can suggeset ebay and amazon with out knowing what you want.
