Honda CR-V & Element 2WD & 4WD Element & CR-V
1st Gen Cruise Control Noise
Old Jan 22, 2013 | 05:01 AM
JZiggy's Avatar
Default 1st Gen Cruise Control Noise
Hey guys,
I took our 2000 CR-V EX auto on a long road trip this weekend and it started doing a weird thing. When cruise control is engaged, there is a clicking, squeaking, or scraping noise from the gas pedal. It happens when it changes throttle position (like starting to go up or down a hill). When you manually press the gas or put a little pressure on it the noise goes away.
The problem is isolated to the cruise control. During normal driving it never happens.
Looking at the pedal, there's an extra arm that the cruise cable pulls on that then pushes on the main gas pedal. The main pedal has some little soft plastic bushing, so my thought is that this thing could be worn out.
Has anyone ever had this issue? Would you recommend just spraying grease on the pivot and sliding points?
Old Jan 24, 2013 | 03:44 AM
JZiggy's Avatar
Default Re: 1st Gen Cruise Control Noise
Put some silicone grease on the plastic bushing, problem appears to have gone away.
differnc
Aug 28, 2009 03:56 AM
brandobot89
Dec 21, 2008 04:47 PM
Ross 2.0
Sep 2, 2006 05:38 PM
Hairy Gorilla
Jul 15, 2003 09:00 PM
