Distributor Cap
Can someone tell me where I can get an OEM distributor cap. There's no part number on the cap itself, and because the car also has an MSD ignition, I'm not sure whether it would be a factory cap or one from MSD? Input appreciated..
Jon
Jon
Thanks for the reply. I actually found out today that the distributor cap was most likely something aftermarket to accommodate an MSD ignition. Rather than the standard 4 openings on the OEM distributor cap, there are 5 total opening spouts (4 in the standard locations, and an additional taller opening). Does anyone know where I can find a replacement cap like described? Thanks in advance.
1) What are you doing where you need an MSD ignition on a Type R?
2) OEM parts = dealership. Or, contact MSD to see what cap you need for their setup.
Regardless, it is an easy question to answer for yourself.
dyg2001
Feb 24, 2004 09:38 AM
