Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
1997 Odyssey battery light problem
Old Jan 21, 2013 | 05:40 PM
legionbuck's Avatar
Icon6 1997 Odyssey battery light problem
My wife's 97 Odyssey had a battery light come on . We tested the alternator & battery at AutoZone, and the battery was bad...was the FACTORY ORIGINAL !!!
Replaced the battery, and the charge light / ABS light comes on intermittently or for long periods...and the lights dimmed / heater fan slowed down occasionally.
What gives ? Bad cable / connection somewhere ? Or something more expensive ?
Old Jan 22, 2013 | 03:04 PM
Myroslav69's Avatar
Default Re: 1997 Odyssey battery light problem
Bad alternator. Probably the voltage regulator inside is going bad, or the brushes. I would buy a new alternator and put it in.
Old Feb 12, 2013 | 04:28 AM
forted's Avatar
If you test the alternator when the light is off the alternator will most likely pass the test. You need to test the alternator when the light is on. The problem is going to be the alternator.
Old Mar 31, 2013 | 04:51 AM
kfray's Avatar
+1
meelow
Apr 29, 2010 09:35 PM
jxhxb
Jun 10, 2009 01:35 PM
Alexnaderkeith
Sep 10, 2003 08:32 AM
