Water pump and belt
But whay sould i change the tensioner? dont think its mentioned in the maintenance schedule.
car got 105 K miles.
Because you're down there, the part is cheap, and it's one more (simple) step. When you replace tires, you replace valve stems preventatively. When you replace your valve cover gasket, you replace your spark plug grommets preventatively.
Replacing a timing belt and water pump is a time consuming, slightly complicated task. You might as well go ahead and replace the tensioner while you're down there just to be safe. Otherwise, when it does decide to go out, you just have to go through the entire process again to replace it, assuming it doesn't take your motor with it.
Just curious has anyone ever seen a Gates water pump fail?
I've used them for years and never had a problem.
I get the Gates kits from RA.
As for why change everything in there? Well as said you have it apart and it's not that much more work.
To put it in perspective. People always say "Highway Miles" in for sale ads. So if a car was driven 105k miles at 60 mph at 3000 rpm, the crank will have turned 315 million revolutions/cams half that. Why would you leave a under $10 seal in there?
I have also found it best to just order the front(left) engine mount when you order TB parts. It's going to be bad anyway.
Get your pump from Honda. The aftermarket pumps are a totally different inferior design that will cause leaking, poor performance, heartache and suicidal thoughts.
Also, use a proper torque wrench (inch lb.) and great care torquing the delicate pump to spec. Make sure the block gasket mating surface is immaculate. I've been known to put a very thin bead of HondaBond along the pump o-ring.
BTW Honda isn't making the pump they are sourcing them. Same as the belt.
scubacamper
Apr 14, 2015 06:04 AM
hilde123
Apr 26, 2010 06:19 PM
92integraVTECgsr
Jan 30, 2007 01:02 PM
