[NJ] Lots of Stuff for sale Check out the list
Located in North jersey for local pick up
Shipping at buyers expense
paypal verified.
I am not online as often as i would like so fastest way to reach me is texting
2016873396
I have a bunch of parts for sale
Everything is priced fairly so no lowballers. reasonable offers will be considered
Read the list if it isn't listed I don't have it. I will update the page as items are sold and as I add new items for sale.
JDM EK9 thin side moldings $100
passwordjdm carbon fiber airbag delete tray $75 mint condition
stock 96-2000 spings $40
ek coupe/hatch gray door panels complete for manual windows $50 each very clean
ek coupe gray back seats $50
ek four door beige front seats $50 each
ek dark gray center console armrest with brand new oem honda mounting bracket $65 (previous owner drilled a small hole for a switch in it and it is missing the rear filler panel/rear ashtray)
ek dark gray center console with shift boot $40
96-2000 complete auto to manual conversion
everything you need to swap you auto trans for a d series 5 speed $350
clutch pedal, master and slave cylinders, clutch line, flywheel clutch and pressure plate with bolts, trans torque mount with bolts and rubber mount, shift linkage with bushings and shifter and ****, shift boot, converted auto to manual engine harness, p2e obd2b ecu, intake manifold with 2 wire iacv, 98 lx 5 speed trans. (trans makes some noise needs a new input shaft bearing. but still works, and axles.
Ek manual trans mount bracket d and b series (trans side) $20
Ek driverside engine mount $35
Ek rear mount
D seriea a/c bracket with torque mount $40
D series ek powersteering pump $40 obo
Full ek with d series a/c setup $80
D series y8 style intake manifolds $30 each no sensors
D series y7 manifold $20
D series starters 1 manual works fine $40
D series obd2 alternator $50
B series obd1 and 2 alternators $50 each
B series flywheel $30
B series 92-2001 clutch discs $20 each
B series shift linkage $70 each set
Manual obd2b p2e ecu $70
Manual obd1 pr4 ecu chipped and socketed has a skunk2 chip in it with 8500 rpm rev limit $100 can convert ecu to be vtec (identical to a chipped p28) for an additional $50
Manual obd1 p05 $50 (can make it identical to a p28 for an additional $50 or chip and socket it and make it vtec for $100 more)
Obd2a to obd1 step down harness $30
OEM Honda brand new in box s2000 ignitiom coils $30 each I have four
Clutch cable for cable transmissions $20 each
5 speed pedal set for 90-93 integra $25
Black interior for 90-93 integra $200 for everything except seats
98 civic lx beige front seats $50 for both
92-95 civic airbags dark gray $100 for both
96-2000 civic air bags $100 for both
97 civic engine harness (was auto but converted to manual properly) $100
97 green civic coupe trunk lid $40
90-93 integra front knuckles with new wheel bearings $40 each
3 sets of integra ls calipers $50 each set
96-2000 civic dx front calipers $50 for both
96-2000 civic dx passenger side rear trailing arm $40
96-2000 civic oem rear lower control arms $30 for both
96-2000 civic front upper control arms with good ball joints $25 each
92-2000 civic front lower control arms $30 each
96-2000 civic front subframe $50
96-2000 civic power rack and pinion $50 (80 with powersteering lines)
90-93 integra front camber kit $50 (upper control arm style)
90-93 integra ingals front camber kit $30
text 2016873396
paypal verified.
2016873396
Ek rear mount
text 2016873396
HondaTom87
Jan 30, 2013 01:22 PM
yurmom562
Nov 30, 2008 02:46 PM
