usdm h22 swap tech
Old Oct 20, 2002 | 05:02 PM
Sohc-Vtec's Avatar
Default usdm h22 swap tech
I am considering a usdm h22 swap into my 96 civic ex. Someone who has done the swap give me an idea on price, no labor just for the motor, tranny, ecu, shift linkage, axels...etc. I know i need mounts, but is there anyway that i could keep my power steering?, i dont need the ac, but i wanted to know if i could keep the power steering. Thirdly what is everyone's opinion on the h22 in general?
Old Oct 20, 2002 | 05:18 PM
Archidictus's Avatar
Unceasing Measure
Default Re: usdm h22 swap tech (Sohc-Vtec)
h22a about 2800 shipped from www.hondamotorsonline.com with tranny, axles, ECU, everything you need...except mounts which you should order from hasport. I think they have a special bracket that can keep your p/s, but don't quote me on that.
it's an awesome swap that I will be doing when I get some money
NrG's Avatar
NrG
h22 swap in civics are nice, but just hope you have good tires, if not, you'll be loosing too much traction off a launch..
h22 in a hatch is very bumpy... car shakes like hell off the line heh
Old Oct 20, 2002 | 05:37 PM
Unceasing Measure
Default Re: usdm h22 swap tech (NrG)
an excellent cure for this problem is a urethane suspension kit and Z10 radius arms. it'll drastically improve launches and all-around traction, as well as handling
Old Oct 20, 2002 | 05:47 PM
MPower332TI's Avatar
Default Re: usdm h22 swap tech (Archidictus)
z-10 radius arms dont fit on civics with h22s....the bar hits the oil pan on the drivers side....i paid 2450 shipped for a jdm h22..mounts and shift box were 900..i spent around 5k all together..did swap myself...about the traction thing, its not bad unless u want it to be...if you can drive u can keep it under control...duh i likes mine
acclude23vtec
Oct 31, 2005 04:59 PM
si foo
Jun 27, 2003 03:15 PM
rkn527
Mar 26, 2003 06:04 PM
sneak
Nov 29, 2002 07:12 PM
iwhichisme
Sep 28, 2002 02:06 PM
