1996 GS-R.
Hey Guys i have a question.. I had my integra parked in my garage .. and I went to go turn it on and it wouldn't start.. i turn the key and you can hear the beeping noise.. but the light on the dash are really dim... I did notice that when i would try to start the teggy it sounded like there was a clicking sound under my dash bored... i checked the fuses to see if any were popped.( i do have an alarm system i had put in). everything looks good ill double check them as of right now the battery is dead.. questions being.. is it a bad battery ..
Yea.. i tried jumping it... but no go .. That what i was thinking.. it sounds like it getting current under the fuse box... all fuses are giid no popped ones..
Does it fire up intermittently? Has this happened before, then gone away, only to come back again?
Could potentially be a completely dead starter if it's making a clicking noise and not turning over. Take a broom handle and bang on the starter a couple of times, then try starting it again. If it starts up, it's your starter going out.
I don't think your alternator because it's still not firing with a jump.
flood
16
Jul 12, 2013 04:40 PM
