B20 wont fire/start in car ? NEED HELP ASAP
alright guys, ive got a 2000 Acura Integra that ive had for about 6 months now. my GSR recently broke a thrust washer so i bought a B20Z2 to roll around with until i get my GSR rebuilt. before i start i will say the car was boosted before i got it, which i learned the hard way so im not sure of what all other than what was on the GSR when i took it out. now that ive put the B20 in and hooked everything up right, the engine wont start. i had to repin my B20 distributor that came with the motor to get it to fit with my harness. all that was done right and still no start. i took my chipped P28 out, thinking that was the problem and put in an OBD1 P75 and still nothing. Now, the engine wont stop priming which i dont understand either. i dont get why this thing wont start and i need all the help i can get to figure this out because its my daily. any help would be appreciated. thanks in advance.
So, by "not starting" do you mean engine cranks, [starter motor works] but engine will not fire, [start], or will it not even crank, [starter motor not working]???
Have you confirmed that you have a good spark and fuel pressure? 94
Is the harness and distributor obd2 still or was that switched?
I know with my swap I had to get an adjustable fpr to increase the amount of fuel going in to have it stay running. It really has to be tuned to have the fuel maps sorted out.
Does yours just crank and crank or will it turn over at all?
civilsantana
Sep 2, 2016 11:07 AM
Frank_2.0L
Sep 20, 2005 07:21 AM
