04 Civic Sedan -- Front Speaker Upgrades
I've been looking for some cheap speakers to upgrade the crap in my 04 Civic. While it seems like 6.5" will fit, the description from the following has me a little concerned:
http://www.crutchfield.com/learn/200...vic-sedan.html
So I take it that the factory speakers' mounting holes don't work with those from the ones in the aftermarket speakers then? Anyone that have upgraded the speakers in their 01-05 Civics care to share what they did?
Front speakers: Your Civic came from the factory with one of a couple of speaker options for the front doors: a standard 2-speaker setup, or a 4-speaker configuration with tweeters in the sail panels. Most 6-1/2 inch speakers fit easily with the help of a mounting bracket, and the common size means there are upgrades for any budget. The factory speakers are kind of an odd size, so you'll have to drill some new screw holes to replace your speakers no matter what you put in there.
This is the diy for front speakers in a civic sedan 01-05.
https://honda-tech.com/forums/honda-civic-2001-2005-78/guide-remove-side-panel-speakers-1914437/
https://honda-tech.com/forums/showthread.php?t=1914437
Obviously my forum search skills are absolute garbage...
