Honda CR-V & Element 2WD & 4WD Element & CR-V
1997 CR-V Misfire -Need Help. Compression and Leakdown passed.
Old Jan 20, 2013 | 12:19 PM
CLCrandall's Avatar
Icon3 1997 CR-V Misfire -Need Help. Compression and Leakdown passed.
Got a problem with my 1997 CR-V (204k miles)
Here's the story:
Replaced plugs (with Bosch), distributor cap, rotor, then car would not start.
Troubleshoot. replace most of ignition system, starts and runs after replacing coil.
OBD starts throwing P0301, P0303, P1300 & P1399
Replace plug wires - still codes
Check valves (engine cold) - all in spec, middle of acceptable range) start engine, now idle is high, uneven - still codes
replace cap, rotor and wires with Honda oem parts - still codes
Do compression test - passed all cylinders just under 180psi (178 is spec)
Do leakdown test - passed.
Replace ENTIRE distributor (AutoZone) still codes)
Cleaned filter screen on IAC.
Note that by still codes, I mean that I reset the OBDII each time and they came back.
what else can I check that would cause a misfire? Every search I do comes back with burnt valves. However, valve adjustment was in spec, it passed the compression test, and leak down test. no other codes are coming up.
Anyone have any ideas?
Thanks!
Old Jan 20, 2013 | 01:26 PM
LDForget's Avatar
Default Re: 1997 CR-V Misfire -Need Help. Compression and Leakdown passed.
oem plugs are ngk. did you gap them?
Old Jan 20, 2013 | 03:36 PM
ARMED's Avatar
so whats the problem? idles up and down?
Old Jan 20, 2013 | 04:40 PM
CLCrandall's Avatar
Plugs are gapped correctly. Idle is high and I am still getting misfire codes for cylinders 1 & 3. All misfire codes have been for 1 & 3. Like I said, it passed compression test and leakdown test. Valve adjustment in spec. Plugs are from honda dealer. Misfire codes show up regardless of plugs installed ( new Bosch, new NGK, old NGK ). Plug wires are from honda (new). Distributor is new (Autozone). New fuel filter also.
Old Jan 20, 2013 | 06:24 PM
Dc2_ShowStopper's Avatar
I had the same problem .. Turned out to be my spark plugs I replaced with NGK plugs platinum and everything went smooth ... Hope this helps
Old Jan 20, 2013 | 07:15 PM
sliverSE.V's Avatar
^never put bosch in Honda...get problems, they are worthless/waste of money..ngk or nothing
Old Jan 20, 2013 | 07:32 PM
X2
Old Jan 20, 2013 | 08:43 PM
shermanyang's Avatar
if everything else checks out good...I would suggest checking your timing belt and your timing...make sure everything is correct.
Old Jan 21, 2013 | 05:53 AM
CLCrandall's Avatar
All timing marks line up. Timing belt is good. Plugs currently installed are NGK from the Honda dealer parts counter.
Old Jan 27, 2013 | 08:53 PM
jdm_bones's Avatar
could be poor fuel pressure to cylinder 1 and 3, meaning that perhaps your injectors are not operating properly. i'd replace them, and fuel filter while your at it, and test your pressure.
Old Feb 3, 2013 | 11:10 PM
www.megameet.org's Avatar
Crank sensor
Old Feb 4, 2013 | 05:29 AM
blackskunk2si's Avatar
x2
Old Feb 4, 2013 | 01:03 PM
11SECEG's Avatar
Originally Posted by www.megameet.org
Crank sensor
+1
Old Feb 6, 2013 | 07:47 AM
razcob's Avatar
What was the final outcome?
Old Feb 10, 2013 | 05:31 AM
dnguyen2010's Avatar
Maybe your spark plug wires to cylinder 1 & 3 is backward.
Old Feb 10, 2013 | 05:33 AM
have you verified if your wires setup/install correctly.?
Old Dec 13, 2016 | 11:50 AM
khellapeter's Avatar
yeaaa have you found a solution?
K-G
Sep 14, 2019 10:36 AM
blueberryEG
Jan 25, 2014 12:55 PM
mimog3
Nov 19, 2012 05:36 AM
gohonda
Mar 23, 2008 03:52 PM
photec3
Jun 25, 2007 11:23 PM
