HELP build bottom end will not turn over by hand
Old Oct 20, 2002 | 04:46 PM
ls_vtec_b18a1's Avatar
Default HELP built bottom end will not turn over by hand
im building another ls vtec and heres the problem. i got a b18a1 block with b16 pr3 pistons on ls rods, with arp rod bolts, ive put neww rings and bearings in the motor but when i tighten the rod bolts 23 foot pounds the motor wont turn over its locked up tight when i back it off it turns over fine. whats up with this.
[Modified by ls_vtec_b18a1, 9:49 PM 10/20/2002]
Old Oct 20, 2002 | 05:35 PM
Steve-o's Avatar
Default Re: HELP build bottom end will not turn over by hand (ls_vtec_b18a1)
you could have the berrings in wrong but did you lube it all before you put it all together? you crank my be out of round,,,did you machine your block to specs? take it all arart and start over and go slow make sure every thing is lined up right if all this doesn't help post again and we well do some work!!
Old Oct 20, 2002 | 05:40 PM
Default Re: HELP build bottom end will not turn over by hand (Steve-o)
i know that the bearings r right and i did lube it. but i left the bottom end stock, i just took out the b18 pistons and install the b16 ones, i did hone the clinder walls
Old Oct 20, 2002 | 07:45 PM
Bgladfelter's Avatar
do you have the head on?
valves banging?
Old Oct 21, 2002 | 06:33 AM
Default Re: HELP build bottom end will not turn over by hand (Bgladfelter)
no its the block with no head on it
Old Oct 21, 2002 | 07:35 AM
DonF's Avatar
If you mixed up the rod caps and did not put them back onthe same rods it would do it,or you did not have the big end of the rod resized when you installed the ARP rod bolts.
InTheLBC20
Sep 25, 2010 07:00 PM
TylerLorenz
Mar 10, 2010 07:46 AM
LSVTEC 91 Civic
30
Mar 29, 2005 05:40 PM
h22a193
Nov 14, 2004 10:16 AM
TurboDC4
Aug 4, 2002 08:56 AM
